Results 1 to 11 of 11
    Default egr off Lancia Musa edc16c9
    I would like to disable egr on this file! help me?
    I bring three break points to 12000 points or pave the controls?
    some of you can do it without turning on the light engine?
    ALGERIA
    try and repport
    pw.............pm
    Quote Originally Posted by grinovsky View Post
    try and repport
    pw.............pm
    thanks grinovsky can check my edited file and say what do you think?
    you have a file that I see gold edc16c9 + mod?
    ALGERIA
    sorry mariooo
    bad tuned,i see that you know how to use winols
    and now you have to learn what you have to mod and what you don't have to modifi
    sorry mariooo
    win ols still use it wrong you can give me some advice? because my file is not good? What should I fix? I could do to see how you do it this file? how many hp can you get out?
    ALGERIA
    every tuner have his proper way to remap and the result is the same(more power) and you have to developpe your way ,this come whit experience and great learn
    the life is a school
    these lessons are the experiences that we live
    his teacher is the time
    you think I can prove my file? second I have problems? I think not but what about you?
    Quote Originally Posted by mariooo View Post
    grinovsky
    could you give me your vote on a second test file mod muse?
    closed with egr limiter let him smoke is gold right?
    ALGERIA
    bad, bad, bad
    the probleme with you is that you don't know what do you do when you tuned a map,
    how many power you add in engine when you tune the rail presure map like this?
    answer:zero power will be add so why you modify it?
    you can learn how to tune a dump if you use only ecm2001 and the help that come with from an italien tuner,he explaine how exactly tune a map
    ALGERIA
    this how tune the maps with ecm2001
    so try to anderstande
    and after that you can use winols
    you must instal image ready to see the document
    If you do touch this file such as addresses?
    Can you give me the addresses?
    I did not understand what is wrong, the wrong rate or the maps?
