Gutsah (26th December, 2023)
Hey,
can anyone help me out with bcb-file for:
Hw: 0261206060
Sw: 1037356925
hi, please i search file for this ecu:
Alfa Romeo 146 1.6 TS - 88kW
Bosch
0261204944
1037350819
thx to all
++++ GOOD WORK ? + ++++
FIAT EMEA 7inch, Ford Sanyo, DELPHI Chrysler Jeep Dodge, DELPHI Volvo GMC Renault, Ford FIC, Fiat Turkey, Ford V Series Calc, Fiat Continental VP1 VP2 Calc, Opel Delco CDR500 & CDR2005 Calc, Mercedes Alpine Calc, Jaguar Alpine Calc, Fiat Daiichi Calc, Delphi Famar Fueguina Calc, Renault Calc, Dacia Calc, Grundig oldtimer Calc, Chrysler Jeep Dodge Panasonic Harman Becker Alpine Continental Calc, Blaupunkt Calc, Philips oldtimer Calc, Audi Aisin RNS-E Calc ....
HELLO
I NEED 2 FICHES VIRGIN AND ORIGINAL ECU FIAT BRAVA
M1.5.5 0 261 206 276
PLEASE HELP ME
This is the original file 0261206276 (not tested), you need to convert it to BCB format if you're gonna write it with Galletto 1260.
To make it virgin you need to put ground to SDA and flash the COD file you find here.
Next remove the groumd to SDA and flash it with the ori file.
Remove immo box before installing the ECU to the car.
Hello.
Pin SDA must be connected to ground while I write COD file or only while I start ECU?
I connected pin SDA for moment, while I started ECU and FES showed programmed date: 00/00/0000.
It's enough?
Fiat Brava 1.2 16V - Bosch M1.5.5 0 261 206 276
Sorry, my english is poor
P8, P17, P18 - 12V
P11 - K-Line
Gelletto shows "Errore invio INIT2", while I try write COD.
ECU is detected correctly.
What is a problem?
No ideas?
I don't find resolve in web. Most problems are with INIT1 and INIT2. I have only INIT2 error.
Yes, I tried with P10 connected to 12V. Result is the same "Errore invio INIT2".
Power supply voltage is 12,1V
Ground is connected to ECU case.
Ok, problem is solved. I used other galletto interface.
I have different question.
Does anyone have pinout of MCU in this ECU? Is this C509L?
Hello Everybody,
I have read all this thread with attention to find some answers to my questions, so many thanks to all contributors with their precious experience.
Actually I am rebuilding a 2.0 TS petrol engine to replace the old 1.8 TS engine of my Alfa 156.
The ECU M1.5.5 of the original 1.8 TS is working fine but I guess I could have issues when the 2.0 TS will be transferred in the car...
Can I buy a used 2.0 TS ECU M1.5.5 and put it in the car without any "immo" issues ?
Or do I have to reprogramm it with the procedure described in the previous posts ?
Thanks for your answers
