Results 1 to 7 of 7
Thread: golf5 r32
    Default golf5 r32
    hi,
    i have a mpps and im having problems reading ME7.1.1 always gives error at 6% and stop reading.
    Anyone knows waht to do??
    what error do you get? also try reading directly to the ECu using the pinout of me7.1.1
    rossoelab's Avatar
    Italia
    files in the ECU is original or mod?
    perhaps does not read because the file is encrypted
    Top Poster + TECH's Avatar
    I had the same problem .... was a tuned and lock file as I find later..
    DK Veteran rappttor's Avatar
    PERPETUUM MOBILE
    see if all is stock on the ecu pcb
    try directly to th epins using a power suply
    should work
    DK Veteran rsibiza's Avatar
    Exclamation
    This ME7 i suggest unsolder flash 29Fxxx read and write it this way..
    A friend bricked his ecu,reading and writing back its file...
    After this i tryed rewrite flash paralell..no way...
    Safe way..i suggest..paralell programmer
    problem isn't clone mpps is other!
