Results 1 to 8 of 8
    justy22's Avatar
    May 2009
    UK
    Default 2005 RENAULT SCENIC 1.5 DCI NEW CLUTCH FITTING advice needed
    Can anybody advise me on fitting a new clutch to my 2005 scenic 1.5 dci do i have to drop the subframe, can i push box aside and replace clutch without dropping box
    cheers all
    Jul 2009
    hi justy22
    i have done quite a few of these my preference is to take the subframe out
    but it is possible to drop 1 side and push the gearbox inbetween subframe and chassis rail
    also put pleny of wd40 on subframe bolts as the cages that the nuts are in tend to break, this is not a problem as you can get to them
    hope this helps
    tony
  3. The Following User Says Thank You to tonyboy101 For This Useful Post:
    justy22 (22nd April, 2015)
    Apr 2014
    all diesel scenics 1.9 and 1.5 i drop the frame it makes it alot easier getting the box back in
  5. The Following User Says Thank You to sjc1 For This Useful Post:
  6. #4
    Meat-Head's Avatar
    A job like that you would be better off farming out to a local garage, say www.meat-head-motors.co.uk
    i know this sounds strange, ring around get prices, call dealer see if they price match, you know it's going to be a crap job, dealer often will charge xx hours no matter joe long it takes
  7. The Following User Says Thank You to Meat-Head For This Useful Post:
    justy22 (24th April, 2015)
  8. #5
    justy22's Avatar
    May 2009
    UK
    Quote Originally Posted by Meat-Head View Post
    i was gonna take it to MHM but too scared i would end up with a hidden remote cut off switch timed to work when i hit the M6 at rush hour when taking car home
  9. The Following User Says Thank You to justy22 For This Useful Post:
    Meat-Head (24th April, 2015)
  10. #6
    Meat-Head's Avatar
    Not your car, just as you sell it, GPS makes the CORRECT TRUE milage show on the dash
  11. The Following User Says Thank You to Meat-Head For This Useful Post:
    justy22 (25th April, 2015)
  12. #7
    justy22's Avatar
    May 2009
    UK
    Remember that old 80 yr old biddy complained about the cut off switch you fitted, u gave her 10 rapid in the pancreas
  13. The Following User Says Thank You to justy22 For This Useful Post:
    Meat-Head (25th April, 2015)
  14. #8
    Meat-Head's Avatar
    No that was Arnold Rimmer the then MP for printing his proper gander in a northern town
