Results 1 to 8 of 8
Hybrid View
    Default 2004 Hilux synchro problem
    Hello
    Please permit me to solicit your help concerning a 2004 Toyota Hilux i have here with the problem of Lost of synchro between IMMOBOX and Engine ECU.
    In fact being able to add 4D transponder data manually to immo dump, i am hereby looking for a good pair of IMMOBOX / Engine ECU dumpsi will used to swap these items and then write the existing key in the new dump.
    Please if someone has working pair of dumps IMMOBOX/ECU (from a case of all keys lost he may have solved) that i could used to program ECU and IMMOBOX, of this car and then replace one of the key in the immo dump with the following existing key data,please send them to me.
    Recognizing transponder...
    Transponder recognized as Texas Crypto
    ID4D - 67 - JMA TP xx
    Password: 92 - Locked
    Identifier: C6 - Locked
    Serial number: 1ADC3A0A - Locked
    Secret key: Locked
    Attached here is dump from the car that may anyone willing to help, to search in its data base the corresponding.
    Please awaiting for your reply
    barelang-kepri
    Ngakson !
    What engine type ??
    South Africa
    blue or black box or easier supply part number of ecu immo box
    ecufix
    ''blue or black box or easier supply part number of ecu immo box''
    ECU IMMOBILIZER : TOYOTA 89780 - 35070
    South Africa
    exscuse delay , problem solved ?
    Default hi
    ok frind
    whay u dont use vergin dump?
    I replied your an email. did you try my suggestion out
    Sent from iPhone 4S
    vanos batam's Avatar
    Batam-Indonesia
    Quote Originally Posted by ngakson2002 View Post
    Hello
    Secret key: Locked
    try it.....
