Results 1 to 8 of 8
    Default willem programmer and a laptop
    hello friends..
    today i recieved my willem prog and i am a little bit confused.....i have only laptops to my job......i need to install the soft of the programmer and it tells to connect the programmer and my pc with the db25 parralel cable...and the usb port.......the usb port i connected with my laptop but the db 25 cable no,because my laptop hasnt got this port.......is there any converter cable from db25 to usb????can i do to this way or not????can willem prog work with (only usb laptop??)
    Jun 2009
    You need parallel port, USB is only used for 5V supply. It's not USB programmer. You need new programmer, or old laptop
    Meat-Head's Avatar
    cool, more intreasted in a link for the software for it, don't understand chinaman!
    thanks MH for your reply.....can be more specific?i appreciate your interest!!
    Meat-Head's Avatar
    i have same unit, but the software that was 'included' said click this link, goes to all chinese website!
    you could TRY a usb to serial adaptor then a 25 pn to 9 pin adaptor, might not work
    Sivava has 0.98d5: (SIVAVA - Download Software Versions 0.98D5), pcb4.5c
    @d.zio: there are usb2parallel cables, but i think they only work with printers, since they have centronics connector (not db25).
    Maybe a pcmcia card with parallel port can help you.
    Jun 2009
    USB2parallel doesn't work, I tried. PCMCIA might work, but I newer tried. My programmer is from sivava.com, I'm using old laptop with rs232 and parallel for all programmers. USB2rs232 and converter to db25 cannot be used with willem, it need real parallel port... There's another cheap solution for universal (real) USB programmer. MCUmall Electronics Inc. A low cost EPROM EEPROM Atmel PIC I2C SPI programmer online store
    aissa09's Avatar
    Blida Algeria
    willem's a good programmer I built it a long time there 's Version 3.
    preference must change the PC with 25 db in all cases you are not losing
    Listen
    Read phonetically
    Best regards aissa
    AISSA SERVICE ELECTRONIQUE
    BLIDA car radio decode
