I have the same problem!!!
Please share this dump to all ):
BR
Fifas):
Anyone have the MC68HC16Z1 dump from the Can board of the renault CLIP interface?
this Motorola its the fault when clip is asking firmware and stops to 20% .
this go broken and must repalce motorola and write the fresh soft in side.
SO i need the MC68HC16Z1 dump if anyone will be kind to share.
dont talk a lot and nothing
BR
Fifas):
what i have found out today , trying some clips damaged on some laptops was that.Was asking firmware and stuck at 20% and i tried on clip v95 but on different laptops.
On dell D620 worked fine and not asking firmware,on other HP and Asus laptops , same V95, did not. stuck.
So i think also the usb of laotops is lazy on some laptops.
Dell d620 is great cool laptop .
but other clips did not work at all even on D620, some worked , some not.
so still the motorola freescale is problem in clip . The mcu its fake, manufactured who knows where... thats cause.
I have met this problem also for vagcom, have fake atmega 162, not good chip. even erase and reprogramm via HVPP, the fuse bits were not working and cannot be set. so vagcom not working properly on some protocols.
changing the Atmega with an original manufactured one, vagcom worked fine.
THanks me !
I have the same problem.
Did you managed to get that MC68HC16Z1 and to get reprogramed?
Did it solve the firmware upgrade problem?
Hi, same problem here.
The question is how to read/ write MC68HC16Z1?
The 4 led on don't mean that AN2135SC in good, maybe it
have problems to transferring information!
I have a Original Renault CAN CLIP.
I can help you.
What can i use for read this MCU?
I have Xprog-M, UPA USB, Xeltek U280, TU (tacho universal), DP3, codiprog USB.
Regards.
I don't know any programmer to do this
MC68HC16Z1 has no memory of programs. The program in 28F800
p.s. Look what IS SRAM stand near to 28F800
Original have samsunf 519a k6x1008c2d-pf55 TLpc33z4
Clone have samsung 407a kgx1008c2d-tb55 tlpm0411
Original have:
AMD
am29f800bb
-70ec
SAMSUNG
519a
k6x1008c2d-pf55
China have:
AMD
am29f800bb
-90ec
SAMSUNG
407a
k6x1008c2d-tb55
Thanks. Whether there is a possibility to read dump 28f800 iso pcb and can pcb?
My xeltek u280 can read it.
but I haven't the adapter for it and it cost 350$ !!!!
Can I read it in circuit?
I regret - but in circuit only through BDM
