I made this project (esl emulator) and I know what models of working EZS.
if my emulator able to work with the W204, W906 come to me lot of money ....
in this moment work only with EZS from w202,w203,w211 and similar.
Where can we get emulators from ?
regards
locks85
I have a procedure to emergency start the car if esl damaged
-Remove a fuse in rear trunk
-switch ignition on
-put back the fuse
- start car using relay starter in front sam
( work only if esl in open position)
If esl in close position u have to open esl and make it in open position !
Car will start
Have a look at this may be of any help....................
SZH Technology Co.,Ltd
Thanks Ash
Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
HELLO MAY FREIND
THANKYOU
Yes
Put ignition on
Remove and put back the fuse
U will se ingnition in dash
Start the car manually using starter relay or direct 12v in starter
But i need a final solution for 204 elv
I have 2 cars with defective elv
But both cars is blacklisted by daimler
I dont see any solution for them
More easy solution is buy one used ESL and Renew. Work perfect and is cheap then emulator.
Hi.
I'm having trouble on two W204 cars,
ESL does not work (locks Steering)
THIS VERY COMMON HERE IN BRAZIL WITH THESE CARS W204 problem of ESL.
often change the internal engine bolts and works well.
but these cars now is not the problem of ESL engine,
DO NOT LISTEN THE CLICK OF TWO INTERNAL RELAYS,
NEC is a problem or trouble in the circuit board??
you have any tips?
you got the same problem?
Thank you. giovani.
i got serval pm aboute fuse location
attached is the photo of the fuse
hi chakahafed,
How do I turn on the switch in the case of bad ESL.
W906 ESL not lock.
which fuse? it name?
thank you.
906 you cannot do this trick - only w204
W906 hit esl with big hammer!
Mark
