Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 63
  1. #31
    smayer's Avatar
    Jan 2012
    Quote Originally Posted by chakahafed View Post
    i got serval pm aboute fuse location
    attached is the photo of the fuse
    Just one advice, buy a new camera
  2. #32
    chakahafed's Avatar
    nouakchott
    thnx , i will
  3. #33
    Newbie Bundes2011's Avatar
    Mar 2012
    Kazakhstan
    Somebody solved this problem with elv? Or it is necessary to call to the dealer?
  4. #34
    chakahafed's Avatar
    nouakchott
    Call the dealer .
    No one can do this job
    Envoy? depuis mon GT-I9300 avec Tapatalk
  5. #35
    Oct 2012
    How to start car using relay starter. I did remove and reinserted fuse 17 in front SAM and the display lit up..looking good. The next step is to start car using starter relay????? How
  6. #36
    Oct 2012
    How to start car with starter relay?
  7. #37
    bursuc's Avatar
    Oct 2011
    inside MCU
    Just turn that relay ( starter relay ) into ON position , it's like you directly give 12 V on KL55 for starter to turn ON and start the car
    Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
  8. #38
    Oct 2012
    I looked at the front sam box , MBZ does not have the relay marked on the so called manual. Could you please tell which is the starter relay. I searched internet a lot no luck..
  9. #39
    bursuc's Avatar
    Oct 2011
    inside MCU
    you have only 2 or 3 relays in frontSAM under the bonnet .
    Just open 1 relay and manually put it in ON position .
  10. #40
    Oct 2012
    There is a round silver transistor like device 47VFC..
    Is that available online? Also can you please post a pic of the gear assembly. I cannot put it back together.
  11. #41
    Top Poster ettaoussi's Avatar
    Aug 2012
    hello to everyone! which relay must be activated?
    thanks to anyone who gives me a help
  12. #42
    smayer's Avatar
    Jan 2012
    Quote Originally Posted by Rascao2013 View Post
    Free advice: change profession!!, the "round silver transistor" it?s a capacitor!
    To assembly gear you can find help with a 5 years old boy with skils to puzles.
  13. #43
    Member SkyElectronics's Avatar
    Jan 2013
    South Africa
    i have solution to w204 esl.... but it requires u hav a programmer to virginize w202 and w210 type esl
    dont hate me cause im a Red Devil
    without DIGITAL, my life would be KAOS
    if our posts are helpfull press the thanks button
  14. #44
    Jan 2013
    South Africa
    Quote Originally Posted by MarkPRP View Post
    906 you cannot do this trick - only w204
    W906 hit esl with big hammer!
    Mark
    it works with w204 aswell
  15. #45
    Jan 2013
    South Africa
    Default solution
    i havent had the chance to complete this
  16. The Following User Says Thank You to SkyElectronics For This Useful Post:
    ettaoussi (25th September, 2013)
