Page 1 of 5 12345 LastLast
Results 1 to 15 of 63
    kautuvera's Avatar
    Sep 2009
    Default W204 Start Error
    Hi What about this error and how you solved it?
    Car steering lock, and is not clear
    Please if you have information in this area provided me put
    Tanks
    Nov 2009
    workshop
    buy new esl with orange(green)key
    or have You warranty
    Top Poster crackintosh's Avatar
    Jul 2009
    Chisinau
    Inside ESL electromotor is dead... 10000000000%
  4. The Following User Says Thank You to crackintosh For This Useful Post:
    cipijoint (16th October, 2013)
    Sep 2009
    Quote Originally Posted by crackintosh View Post
    Good to know. 10000000000%, I wish I was equally certain about something at some point.
  6. #5
    kautuvera's Avatar
    Sep 2009
    Hi, Thanks for your answer, there is no way to ESL repair?
  7. #6
    Sep 2009
    defaut is in ESL
    BUT NOT ESL electromotor is dead... 10000000000%
    ALL TYPE 204 have this probleme
    i have this probleme 50% IS ELECTROMOTOR IS DEAD
    50% IS ESL
  8. #7
    kautuvera's Avatar
    Sep 2009
    How can I dump file you read ESL from the NEC IC?
  9. #8
    Jul 2009
    Chisinau
    It's imposible to read NEC! This MCU does't have READ command.
    I have 2 W204 today - both with dead electromotor.
  10. #9
    Jul 2010
    HI
    I have problem on w204 esl.i have 2 cars now with this problem.i tested all components on esl board and electromotor,all are ok.eis is 10000% work ok.
    i think they have esl nec software fault.
    is there any way to remove esl and put esl simulator instead?guide me solution please...
    AUTO CODING
  11. #10
    z786's Avatar
    Aug 2009
    10 Steps Ahead of You
    isit me or can you not get more than a 100% (one hundred percent) mayb i went to the wrong school
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
  12. #11
    kautuvera's Avatar
    Sep 2009
    Here I want a circuit ESL simulator, you can create it?
  13. #12
    kautuvera's Avatar
    Sep 2009
    no body ???
  14. #13
    DK Veteran JOHNCICY's Avatar
    Mar 2011
    EAST AFRICA
    I had a w204 start error bt is was the EZS,try an emulator.it also works with w 211
  15. #14
    avital's Avatar
    May 2010
    For W204&W906 ESL(NEC inside) emulator not working.
    Mercedes update system comunication EZS to ESL and close this way.
  16. #15
    kautuvera's Avatar
    Sep 2009
    Default w204 esl simulator
    Quote Originally Posted by kautuvera View Post
    But one of my friends do it has done, there is a way you think?
