Noone?? The chip inside the BDM says : MC68HC11E1CFN3 . Please help!
maybe you have to use xprog ! got to seach !
Yo're saying that I need the Xprog device, or only the software ?
Does anyone atleast know if the MC68 can be reprogrammed trough the BDM interface? or do I need the XprogM ?
With Mprog you can erase the 93C46 eeprom only. the 68hc is still ok. you just need to get the ept-file from a working bdm and rewrite it with mprog.
for programming the 68hc you will need xprog, upa or some other programmer.
Try mine eeprom from BDM100 CMD1255 clone .
ggaltstart (1st June, 2023)
Ok, so I managed to write the ept file... but DimSport still says: no device found.In the list of the USB Devices it's installed as : "Map3D OBD II Interface" . I've uploaded three pics... One has the FT232BL that says : BLANK DEVICE ??
So, what next ?
Here : the three atachements
You need the FT232 file, to reupload with mprog...
I don't have it.
Here's the FT Programmer, if someone could make a copy of his FT232BL file and upload it here please....Open the software, connect the device, press : "Scan and Parse" then save the file.The file must be in *.xml format in order for me to be able to re-write the FT....
No xml file ? it only takes two minutes guys ...
you haven't erased the Motorola chip but the eeprom of the FTDI chip in your device! You need the reprogramm either using FT_Programmer oder MProg, doesn't matter!
Search the forum for BDM1255! The file for the eeprom ist still there!
Best regards!
Sam
Yes... but I need the XML file to reprogram the FTDI... because it says : BLANK DEVICE
So, I've done all above... this still doesn't work.I reprogrammed it with Mprog... no use.What next ?
