Results 1 to 7 of 7
    ivanrpm's Avatar
    Apr 2010
    costa rica
    Default toyota corolla 2005
    Hi brothers, there is a way to kill the inmo of toyota corolla 2005?
    Regards
    Dec 2009
    Hello,
    No way to kill immo in such car.Read immo dump and post here if you have lost key problem
    Regards
    huzzen27's Avatar
    Jul 2009
    On This Planet
    Thumbs up Regarding Carolla
    hi freind,i am attaching the blank code of carolla eeprom 93c56 please programme the eeprom and start your car with 4c chip key no need to code its auto code programme,regards-Huzefa
    Nov 2010
    hi,friend just put this virgin dump in ecu eeprom 93c56 & start the car with 4c key
    ivanrpm's Avatar
    Apr 2010
    costa rica
    This car does not have any key, with a virgin dump i need 4c chip, or just with a copie, the car starts?
    So this is like kill inmo, but the only difference is that you with the virgin dump make the ecu thinks the inmo is working properly, right?
    Regards
    huzzen27's Avatar
    Jul 2009
    On This Planet
    Thumbs up
    Quote Originally Posted by ivanrpm View Post
    Regards
    You just use 4c chip and turns the key to ignition on and directly start the car its not immo off its virgin dump and when you use the 4c chip it automatically codes to the ecu and total thre keys can be copied simultaneously,regards-Huzefa
    Jul 2010
    Must any data if you have great help and no something wrong info
    ecu number ?
    bensin or solar ?
    manual or auto ?
    immo box or chip inside in ecu ?
    Best regard immo_key
