i have installed globaltis v25 and i have activate it...
i connect tech2 and i begin to download verion in italian language, tech2 comunicate perfect and installation goes...
but...(this is my fault), pc go in standbye...
installation is stopped...i restart tech 2 and globaltis...but now tech2 not comunicate ...go in "rsr232 connection mode"but after 4 sec. appears error e4150= software not comunicate with tech2...
i have try to change baud rate, number of port com, cache from 20mb to 60mb,i have try all, but same error, what is the problem, what is the solution, please hel me!!
same problem...
which you have tech 2, clone or Vetronix
is clone....
make a selftest on tech 2
what is procedure for solved this problem? thank
Its telling you the program file you selected will not work or doesnt exist.
in pcmcia i have write version 123 italian language with memory card explorer, but when start and i have initial screen,I press enter nothing happens.same problem if i insert original pcmcia from original tech2 from opel workshop...
version is overmuch update for internal firmware of my tech2? what is the problem? if write other software V.123 in pcmcia have same problem....need old software, for example 121.00..nobody have this version il italian language?
Hello can you tell me how you uninstall drivers for PCMCIA card.
