Hi everybody from Italy. I reached your forum surfing the net looking for solution to a problem: I bought an USB to Serial Adapter (Prolific) to connect my notebook with an electrical safety defice but it doesn't work. I guess it's a driver problem. I'm going to download the driversi in pg 1.
Anyone have some help??
Ciao!
I have same problem, is there another loader could work?
Having similar issues but I am going to try the drive download posted here.
I forked out ?30 for a usb serial port adaptor plus cable from Maplin and same problem that dream up wont see my DM600!!!
The guy I bought it off said I could post it back for him to flash however I will be stuck in the future as I would be unable to flash it myself.
Would a serial port card work as previously stated as I would rather spend ?15 on a card than ?15 posting it back to get sorted?
Hi, i need some pro to help..
currently i m on Win7.. i understand that dreamup need XP to work.. so i download Windows Virtual PC.
I got myself a 9pin PCI express card for my laptop
sometime (should say alway?) when i m trying to flash a image using dreamup by login to Windows Virtual PC... dreamup app will stop at 3% more or less...
i supect is the Windows Virtual PC but i cant explain what really went wrong..
but dreamup and null modem cable seen to be the only choice to do if dm is down..
Hi Harky,
maybe you can try a different version of Dreamup.
I use version 1.3.3.1 and it was ok although the latest version couldn't work.
click on my signature to find the link to download version 1.3.3.1
are you using PCMCIA card on your laptop to connect the null modem cable? where did you buy the PCMCIA card and how much is it?
What to do if you press the "Panic" button or if your Dreambox DM500C can't boot up
http://www.digital-kaos.co.uk/forums/f34/sgstarhub-digital-kaos-image-39241/index250.html#post916350
Problem solved. thanks!
yes download link for drivers dun work anymore
need drivers
A wise man learn more from a foolish question than a fool can learn more from a wise answer.
Download from here - swrc094
Hi Guys,I am a newbie to this dreambox stuff & have got myself a 500c and am trying to flash it,Have tried it on my pc with xp & netbook running win7,Have used many versions of dreamup & have tried using usb to 9 pin,Also 25pin to 9pin,Both null modem cables,Just get connection ready power up dreambox,But no connection,In dreamup have set the com port to the right one but still no joy,Hope someone can help,Thanxs.
