open in any hex editor, find NO READ tag and replace with FFs...
thanks for the reply.but how do i find the "THE NO READ TAG"....
Open it with ecm and use the hex editor, scroll right to near the end and you'll see 'NO READ' in the asci. Once you do it once..................
any hex editor should have an ascii conversion window to the right..look for that string among all those simbols.
select it and you ll se which hex adresses correspond do it. then modify and save. make sure you have a backup copy
that's just for binary files with NO-READ tag.
I guess he is talking about crypted ols-files/bdmtogo that you cannot open.
your a star,many thanks to all...
What is NO-READ tag? How does it come about? never seen this before
send file
Your friends from DK remove protection.
you do not have to think
I have edited thousands of binary files, and have never seen this no read tag... so I am curious to the history behind it
do share
When tuned file is protected you even can't open it in WinOls for compare with ori. Ols will say it's already tuned !
bronec10 (12th November, 2018)
read the thread from the begining,i aint no brain surgeon,but with the bit of knowlegde i have and help from dk members i sorted it......
Hello, could you explain how to encrypt a file with WinOLS? procedure that is used? how to save a file to make it normal encrypted?
