I may be mixing up with the 1.5 but do you have to program injector numbers?
i'm looking for an original flash file for a 2002 onwards laguna 2 1.9dci 100bhp,engine F9Q752,ecu bosch 0 281 010 556 29f400.
the reason for this is that the ecu was replaced as old one had corrosion and now with the new ecu the car starts and is good at idle but will not rev over 1800-2000 rpm,i cannot switch the flash as the old one is destroyed if someone can help me out
thanks.
no injectors to program on this model,i just feel the flash is wrong for the car as i'm getting no dtc's but internally the 2 ecu's have some differences although they are the same part number but still the 120bhp has the same part number as this too so i feel i need to start by changing the flash,i could be wrong but the car didn't have this problem before getting the ecu replaced.
the only difference i see otherwise with the part numbers is below the bosch number the original has 03 and the replacement has 03 printed on the label,could this be the production year possibly?
ok so far i have tried loading the following s/w versions using galleto,
1037351904 no start
1037362720 no start
1037362860 start but limited rpm
according to the local renault dealer the flash is unique to the car and they used alot of different versions and the only way is to replace the ecu with a new one but i still feel its just down to getting the right dump so if anyone has different versions to the ones above i'd love to try before forking out for a new one.
thanks.
Are you check the car with CLIP?? If yes what is the DTC ?
no i haven't got clip but have scanned with delphi and i'm getting several DF codes mainly relating to cam sensor not being recognised by ecu,i was thinking if i could virginise the 95po8 would this leave the ecu ready to be programmed by renault or would i need to virginise the flash too and lastly would i need the renault ecutool to do this?
