emes125 (23rd January, 2021)
Old pin 8427
Try this...
Do not forget to press Thanks and Reputation buttons!
Is a proper code for this radio 9163 ? Can you divorce it for me ?
EDIT: 3854 was proper
code is 3854 and bin devorce!!!
try and report!
I'm glad i was helpfu,don't forget the reputation and thank you !!!
emes125 (21st April, 2021)
I got a DVD 90 Navi with its own CID all is working but to program other functions asks for carpass code, i read the dump with CH341A but OSCR doesn't give me the code, i attach the dump here, thanks in advance:
Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
Mankyro (4th May, 2023)
This was the eeprom under the DVD NAVI reader, is there so another eeprom? I'll check this evening, thanks for your reply
Ok, i'll check the lower PCB, i used the eeprom under the DVD reader not under the CD, i will tear it down this evening, thanks.
tried with the eprom under the CD instead of DVD: OSCR says always wrong file, but from the dump i read code Z6341 twice. I attach the dump from under and also a new reading of the upper one. Thanks in advance
MasterMulder (5th May, 2023), petronijul (5th May, 2023)
I really thank you, but i do not need to unregister, i only needed the code. But i take the opportunity to ask you: how can I unregister the dump? the site "Radio Unlock" gives me error... However for the CID/GID... i have to modify the reader to read the 93C66 chip, i'm gonna do it soon.
Then i have to load the unregistered one with CH341A programmer , i think.
I have another CD30 MP3 that needs to be unregistered: i attach the dump here, thanks in advance:
pin 3558.............
Hi thanks, I knew the PIN, needed the unregistered dump. Or a explanation on how to unregister it, the site Radio Unlock always gives me errors...
