Results 1 to 14 of 14
    Dec 2010
    Default audi a6 abs problem
    hello. i have audi a6 2.5 tdi -150cv 1999
    when i move the ecu(abs) pins the abs whork ok but not evry times i already open the ecu but dont see any problem ....the thru is when the abs fails i move the conector of ecu and whork again,can anybody help whith this thanks ..
    Jul 2010
    ALGERIA
    bad contact between connector and abs centrale
    Feb 2010
    is that a bosch ABS 5.5 ?
    Dec 2010
    hi .is bosch ABS/ASR 5.3 8E0614111AH
    Dec 2010
    hi .i post o foto (its the only way i can make abs ecu work) i think "drinovsky" have right there is any solucio for that..thanks
    Jul 2010
    ALGERIA
    open the ecu and resolder all connectors contact
    Jun 2009
    porto portugal
    Quote Originally Posted by latino View Post
    hi,, you need to cut the plastic cover, and under the fluid you will find tiny wires conecting to plug.. use a microscope, and you will see 2 wires broken. you just need to re-weld them.
    if you dont have experience , or microscope, do nothing.
    good luck
    Dec 2010
    hi .i have a microscope and sume experience .just on thing do you use any kind off expecial solder or a normal solder thanks
    igendek's Avatar
    Jul 2010
    Poland
    Open and post the picture. i1m going to paint You where should you check connections.
    Ashraf6119's Avatar
    Nov 2009
    UK
    There you go.......... if your eyes are good and your hands are not shaking then I am sure you will be able to do the job.........
    Good Luck.........
    removing "snot-like" goo from ABS circuit board- Bluebee pls. read! - bimmerfest - BMW Forums
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
  11. #11
    Feb 2010
    Default abs
    you need resolder this
  12. #12
    Apr 2011
    France
    hello
    What type of product you can do is hold the welding wire?
    thank you
  13. #13
    Nov 2009
    Check the wires I had problems with +12 line
  14. #14
    Jan 2010
    K.Kambelovac Croatia
    Essential steady hand
