FOR FRIENDS TO PAST THREADS.....HERE IS THE PROFF...
SERVICE ADVISOR NOW IS SOPORTED BY DPA5...IF WANT MORE INFO PLEASE SEND ME M.P...
P.D. IM NOT DPA SELLER....JUST A PASSIONATE MECHANIC
GREETINGS.....![]()
GREETINGS.....![]()
mbu (22nd August, 2015)
dude service advisor jhon deere is compatible with nexiq???... thanks
as you have shown, the link on dpa starter oem is RED. this means the program is not installed, or wrong link, i have dpa 5, this jdmain is not to be found on either service advisor cf and ag, 2.6, and 2.8
Please, DG Diagnostics can be used with Nexiq USB Link or is propietary to DG interfaces only?
I would like to test the program if it works with nexiq, please share it. Thanks
DPA V BLUE LABEL on market is the best interface ever ! , but for programs that accepts RP1210 protocol, and for programs that have this dpa in adapter list (same as allison doc)
NEXIQ on market is similar , and also is a good interface.
But this are generic interfaces, DPA V blue label will never work with CNH , and nexiq will never work with Service advisor.
CNH DPA is WHITE, Service advisor NEXIQ is marked with NEXIQ JOHN DEERE EDL label!
It is not the same also because Firmware and Hardware difference.
Regarding Nexiq and Service advisor. Attached you can see what service advisor ask as hardware .
All are special made By Nexiq for John Deere.
It is wrong what you say about DPA blue.Have you ever tested on machine? Or you was satisfied if PC link was blinking. I tell you i repair this machines, and tested one day one Case Wheel loader. Blue DPA will NEVER connect to machine, even if PC link was blinking.
regards,
attached you have cnh 9 pin deutsch adapter pin out
Do I understand right that Service Advisor and John Deere products need RP1210 protocol support? Would this clone then possibly work:
Truck Diag King-Multi Diesel Diagnosis Interface - Heavy Duty And Motor Diagnostic Tools - Product Catalog - China Century Technology(Shenzhen) Co.,ltd
They mention FEATURES: - RP1210A, RP1210B and they also list "Service Advisor".
I have no idea about the product price.
recently i proff myself on cnh machine and works ok....no problem...mine in blue...greetings
