Results 1 to 14 of 14
Hybrid View
    Feb 2011
    Default OTC Smart Cards?
    I was wondering if anyone has any insight or knowledge on copying smart cards. I still have a reader/writer from the old satelite HU cards and I was wondering if I could copy these cards to use on a few scanners I have. The OTC scanners marry themselves to the cards and are 1 time/tool use only. I have 4 of these scanners and I would like to upgrade all of them at once. I would imagine the scanner itself changes some HEX or checksum on the smart card so they can be read again or work on another unit. Would it be as simple and copying the HEX dump and see what changes after the card is used in 1 scanner.
    Things I need to figure out:
    1. Security features on these cards to prevent reading and copying
    2. What type of card this is (KB storage) so I can buy a few blank cards
    Feb 2010
    I have OTC genisys with Old Version 1, 2002 software with smart cards for PathFinder and ABS and I need help to upgrade it can you help ?. I downloaded the Version 3 upgrade software from here some time ago and have not figured out out to upgrade it.
    Regards.
    Dec 2010
    M29W400 flash memory chip inside the scanner contains a tools serial number. Program all of your four scanners with the same serial number and you should be able to update them with a single smart card.
    DK Veteran ibmman's Avatar
    Jul 2009
    Living Hell
    Quote Originally Posted by Bklyn View Post
    And how is it possible to accomplish changing the serial numbers?
    Dec 2010
    Quote Originally Posted by ibmman View Post
    Remove chip from the board, change serial number using a programmer, replace chip.
    Mar 2010
    Ignore this comment, this person has no idea what they are talking about and clearly has no knowledge of how a genisys works nor where it stores its serial number.
    Member TKMobile's Avatar
    Apr 2010
    Backyard
    I also have an OTC 3.0 ..what a mistake that was
    Top Poster rrob311's Avatar
    Jul 2010
    What is a good all around programmer to use for chips? What is a common program to open up the info on the chip?
    Feb 2011
    Quote Originally Posted by twrch View Post
    Please share fine info then
    Sent from my SPH-D710 using Tapatalk 2
    Mar 2010
    Are you going to copy my work and sell it?
    I was just talking to someone else about this and I think someone in the genisys 4.0 thread made a good point. If you publish it online as your own work, everyone will copy it... but since everyone is doing it... at least noone can sell it.
    Looking at the scan tools, it seems that the EVO tool is taking off now. Maybe it's time to make all this stuff public and be done with it. I'm going to order an EVO tool next week and see if it works the same way... If so, then I think info for both tools needs to be published at the same time so OTC doesn't have a chance to defeat the method.
  11. #11
    gmb45's Avatar
    Nov 2008
    park bench, hedge bottom, police cell
    keep the thread on topic and no slagging each other off or its closed.
    Mar 2010
    Quote Originally Posted by gmb45 View Post
    I'm confused. You replied with this >2 years later?
    LOL
  13. #13
    gopelhu's Avatar
    Jan 2010
    EU
    Hi all,
    This card programmer (that i have ) can be read/write any smart card
    Regards, G
  14. #14
    Mar 2010
    No need to read-write them, you don't need the smart cards to activate the apps.
