if your box has this sim and bootloader l would use this any day and the epg setting are easy http://www.digital-kaos.co.uk/forums...9/#post1173150
Tried this and don't know why it doesn't work.
Doesn't make any sense.
I've followed the instruction to a tee and everything seemed to work.
It downloads the epg data successfully, even populates the epg.dat file in /media/hdd/ since its about 6GB.
When I go to the blue menu -> settings -> epg everything is saved correctly and correctly points to the /media/hdd/epg.dat
However when I click menu->information->epg it says 8 events in 4 services and the multi epg has very basic information just on the channels i've previously browsed.
It still seems to be looking at the old epg settings even though i've now changed this.
fyi i'm using a cloned dm800hd gemini 2 with latest cams 2.2.1 and enigma 2 image installed.
A few people have had the problem where the hdd is not seen in crossepg configuration.Has anyone found a solution that does not involve removing the hdd?.My hdd works fine for recording so it seems to be mounted in rw, but crossepg does not see it.
Is this the simplist method to mount a usb for epg thanks.
Andy.
Charming just added this line
/usr/crossepg/crossepg_epgmove.sh
Now my box only boots halfway and is stuck
Andy,
I am using dreamelite blackhole and have tried this on my db800 pvr.
I can't get that epg look on the tv. All I get when I try for single EPG is the listings in a straight line from top to bottom of the screen, but I don't get the epg grid system.
Any ideas anybody?
Scrote
All I get if I do that is a list of things that are on hotbird. Nothing to do with astra
Very confusing
Scrote
yours might be different on cross epg I was referring to mine which is rytec I thought it would be the same for you but maybe not
I can't get this to work I don't have the lamedb settings, could this be the problem?
where i can find setting for dm800se
Can anyone get the EPG to properly work on the dm800se with the:newnigma2-dm800se-10-4-ramiMAHER.nfi....image.
If you're having problems with the crossepg then it may be the version you are using because my mate had the same problem with the new version not working correctly and when he tried the version i'm using it worked straight away ,might just be coincidence but may be worth trying this version crossepg_0.6.2-svn-260-r0_mipsel.ipk.
I will have a look at that tomorrow,but thanks for taking the time to try and help.
