hello
i am trying to build itself ,when be ready and tested i will post all .
hello
Perhaps he brought quite a few cars from one person, then found they had ALL bad there mileages IN-corrected?
Stanley Meyer's water fuel cell - Wikipedia, the free encyclopedia
Let me google that for you
I'm gonna try that on my Renault Scenic!!
I will post the results!!
Adding the exhaust from your HHO generator to the air intake only makes your fuel burn more completely, and more efficiently. Thus it will burn as soon as the spark hits it. A petrol explosion is slow in comparison, so you will need to adjust your timing to receive the spark after top dead center, or your engine might want to pink because the timing is set to receive the spark before top dead center of your piston. Because of engine design they need the small amount of oil left in the cylinder after the power stroke (a bit like running nos constantly strips the bores). Without the oil based fuel the combustion chamber will be dry of all oil, and with only HHO there will be water in its place, not good because of design again. With this hybrid combination you will find a very cheap addition to make you're engine run much more efficient in every way including its efficiency to destroy itself.
Try running it on salt water conducts electricity better and far faster for corrosion.
hmmmm, so there are many problems???
But.... some brands.. like bmw and chevrolet have made some HHO cars!!!
ok, so download a 'oil injecter' for a gas conversion kit
Flashlube Valve Saver System
As for retard timing, that means your knock sensor will be unemployed
I've installed one of the kits to my Opel Combo 1700 diesel!
Well i've seen an 20% increase in the fuel economy! It's not the 30% or 50% sellers promise but it's a start!
A friend of mine achieved a 33%!
My only concern is if this whole system can actually damage your egnine :/
cool combo b or combo c ?
photos?
explain more?
can you put 2 generators on it, to make more damage?
It's a combo b 2000 model!
Photos are at the end of my site
???????? :: InjectionSakis
O_o more damage???? Come on man! Seriously! Is it dangerous?
Don't know as it's a diesel, it works on compreesion of the fuel, but the hydrogen would make the fuel burn more efficently.
Nice photos, shame your site is in greek!
On the gas inlet is it angled into manifold?
1) try removing airfilter out of manifold, replace with external one in airbox
2) never seen abs on combo b!
what mix is in the bottles? how do you trigger it?
Barnum was right their is a sucker born every minute. Using water as a replacement for gas? Give me a break. Didn't we already use water it was called the steam engine. Now even if you could water instead of gas it will be the same bullsh#t just a different day. Water would cost just as much as gas does now since they will tell you we are running out and world supplies are short plus you would paying high cost not only for you car but for water to shower, Drink, any anything else you use water for. If gas prices are putting a dent in your wallet just cut something else you pay for other than gas. Stop going out for dinner. The cost for a meal for two is about what you will pay for a weeks worth of gas. Once gas prices start effecting other parts of the economy then the government will do something about it.
