Plugg it into the car and do a test again
Good luck
Good.jpgproblem.jpgDear All
i hope any one tell me how i can test my cable because i bought this cable from china
when connect the cable to computer and i make test give me good not pluge into car
what's different between old version and new version 12.12 & 15.7
plz check for 2 photo for 2 version 12.12 & 15.7 this test for 2
Good luck
Rabiee (6th January, 2016)
I have 15.7 with 1.94 firmware,, what is de current vcds version now for this device ? can be update to version xxx...?
Very few informations
If the tool it has Atmega162 then can be upgraded.
Chines clone only by flashing
HQ clone by VCDS software. (but I am sure you don't have one of this )
So you need dump and software and programmer to flash your tool to run a newer version
Otherwise stay with what you have and don;t play with it because you will "kill" it
Good luck
Thanks Mate,
it is an standart china clone 15.7 VCDS HEX CAN USB Interface with ATMEGA162 + FT232RL Chip
so I need to flash atmega ? does everything works good after flashing or I can better stand by 15.7 ?
i will search for the stuf that I need to upgrade
