Page 4 of 6 FirstFirst 123456 LastLast
Results 46 to 60 of 78
Thread: 160D0WQ
Hybrid View
    Top Poster camarock's Avatar
    Jun 2011
    I have codiprog, and works well, also I have r270, and also works well, but few times I cant erase some chips, few time ago I know a seller to sell me some 35080s in 2 dollars, and works well, I proved in bmw 2011 and works well, also in opels and land rovers, without problems. cause one time I bought with china dealer and it was a desaster, I cant get back my money and enyone works
    CaMaRoCk
    thanks for thanked
    With codiprog just read eeprom and save then write 00s into top 2 lines where mileage is stored then do miles with programmer never had a 35160 fail this way
    hass42's Avatar
    Aug 2012
    USA
    Can I read 160D0WQ with UPA? or should use Xprog?
    Also I have new M35080 chip Smarti say I can write 160D0WQ into this, anyone try?
    I do not think so 35080 have 1/2 Data
    Moderator
    PremierD's Avatar
    Jun 2009
    Yes you can mate ........................
  6. The Following 4 Users Say Thank You to PremierD For This Useful Post:
    DashProg (1st October, 2015), hass42 (1st October, 2015), Johnner (1st October, 2015), zckariya70 (28th October, 2015)
    hass42's Avatar
    Aug 2012
    USA
    Quote Originally Posted by PremierD View Post
    Ok, I try to write original file off of D160 chip into M35080 and it give me error at address 400 and it pretty much just doubled the file, SO 00 to 3FF is same as 400 to 7FF
    Using xprog, anyone can help in sorting this out for me?
    Hass42
    hass42's Avatar
    Aug 2012
    USA
    Ok, I must be doing something wrong here, I try to write (new chip, have used these plenty with no problems quality chip) 080w0dq with file below with xprog as m35160 and it will double file info after line 400.
    so 0 - 400 same as 400-800. It will reread chip but info is doubled, and during write it gives me error at 400
    I was getting red dot on dash, does anyone know if I have to do something in settings of xprog or anything?
    hass42's Avatar
    Aug 2012
    USA
    But necessary to read as 160DOWQ of course, this is the mistake I made.
    Hass42
  10. #9
    hass42's Avatar
    Aug 2012
    USA
    Any idea on how to read with upa? And I try with xprog and wont work either, I can read upa as m35080 but not all of chip reads
  11. #10
    Faraday's Avatar
    May 2012
    The dark side of the moon
    I use Martech BOX III. Read/erase- no problem. With xprog I had no luck to erase.
  12. The Following User Says Thank You to Faraday For This Useful Post:
    clydey (25th October, 2015)
  13. #11
    smartymarti's Avatar
    Jan 2011
    cornwall
    Iam seeing more and more bmw 7 series that have 35080 inside rather than the correct d160 obviously complete amateurs that cant erase them , so they are working ok all the functions are there and i cant see any difference and there no dtcs relating either
    All about the Bass
  14. #12
    WW
    Quote Originally Posted by smartymarti View Post
    http://www.digital-kaos.co.uk/forums...hlight=160d0wq
  15. #13
    hass42's Avatar
    Aug 2012
    USA
    I have a mismatch dot and every time ignition switch on and off it adds 3 miles
    When I read file from D160 it reads correct, but when I use new D080 chip to write, xprog give write error at address 400 and I continue write.
    After finished, address 00 TO 3FF is as address 400 to 7FF
    Hass42
  16. #14
    Jan 2011
    cornwall
    Quote Originally Posted by hass42 View Post
    Hass42
    why not erase the chip or send it to someone who can for you
    or even better buy an eraser
    All about the Bass
  17. #15
    hass42's Avatar
    Aug 2012
    USA
    Already ordered, just need this vehicle to be done like yesterday . I have 35080 eraser just I never fun into this chip, even though I have done a F BMW with a cas4 before several times.... Just never run into this chip
    Hass42
