    justy22's Avatar
    May 2009
    UK
    Default Renault megane 03 drivers window fault
    2003 Megane convertible all the windows work with the roof switch and drivers window will go up with its own switch but nothing when trying to put it down with its own switch
    Liteace's Avatar
    Mar 2009
    On a rock
    Check the drivers window switch, can't really be anything else
    justy22's Avatar
    May 2009
    UK
    Quote Originally Posted by Liteace View Post
    The switch is ok as ive checked it, i plugged the multiplug in to the rear window switch and still the same
    norfolk uk
    this fault will be the small electonic box attatched to drivers window mech
    Meat-Head's Avatar
    Quote Originally Posted by justy22 View Post
    Quote Originally Posted by shadow12 View Post
    only just seen this thread.
    If it goes down with central switch and up on it's own, the 3 wires, neg ign, up/down are ok - assume switch worked in rear?
    *THINK* as it is french, that the window switch has 6 wires, in/out of the drivers switch, would suggest a broken wire in drivers door pillar
    looking at litace's post it would/can only suggest broke wire in drivers door
    http://www.digital-kaos.co.uk/forums...0/#post1011697
    Oh there is no milage stored in the window modules, so no need to IN-correct it.
    justy22's Avatar
    May 2009
    UK
    Good to see you responding to threads while sober Meaty
