    immokill's Avatar
    Jun 2009
    UNIVERSE
    Default FORD DPF REGENERATION INFO
    Hello
    I`m having priblem with FORD C-MAX 1.6 diesel engine with DPF\FAP filter .
    Is there any instruction how to start regeneration on this Ford model?
    Please help
    Here to HELP!
    Staffs UK
    use IDS
    and there is a workshop code I think
    i guess any good diagnostic tool can do it.
    otherwise, remove the FAP components and disable it electronically
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Quote Originally Posted by ominimicu View Post
    Thank you all
    I have problem with this Ford It has DTC in dashboard c1750 and sometimes goes in safe mode ,no acceleration allowed.
    Any help appreciated
    Here to HELP!
  5. The Following User Says Thank You to immokill For This Useful Post:
    jcac27 (28th September, 2019)
    ohh.. in that case..if you dont have the money to replace the FAP...then remove it. get the flash dump and remove it electronically too.
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Hello
    Solved .FAP removed electronically and mechanically Car run OK. Thanks
    Here to HELP!
