Results 1 to 15 of 20
    Dec 2010
    Default Audi a3 hot start remap
    Anyone can remap this for hot start problem its 2.0 TDI 140HP EDC16U1
    ALGERIA
    this is the solution
    pw......pm
    Dec 2010
    Tested today, but cranking too long before start, maybe just little bit better than with orginal file.
    Probably starter problem.
    ALGERIA
    what's the value of rail presure when you do ignition?
    what's the speed engine when you start?
    Slovenia
    This is a Pumpe-Duse engine, there is no "railpressure" to be measured during startup...
    ALGERIA
    oh,yes,that's right,i
    so ,what is the speed ingine when start engine?
    Quote Originally Posted by TribesMac View Post
    Try this:
    Pass PM
    But I think the problem is elsewhere...
    Dec 2010
    Alfy thanks for helping, but tested that file by myself with carsoft, but very bad and much looonger cranking.
    My opinion that ecu remap will not solve this problem.
    Quote Originally Posted by eduardo74 View Post
    As I wrote before, I think your problem is elsewhere.
    Did the car start OK before?
    You need to do diagnosis test (not only look at faults!).
    ALGERIA
    may be some information about engine?
    Your file is "mapped"... try with original if better:
  13. #13
    Dec 2010
    Alfy, my client didnt confirmed, because car is third hand. Now, I examinated what is problem. Machine is at end of life, somebody before drive it at full power.
  14. #14
    Also bad remap!
  15. #15
    Dec 2010
    After checking engine compression, cylinder leakage, finally removed starter.
    Problem solved. Thanks all to help!
