Results 1 to 4 of 4
    The Stig PT mtv1's Avatar
    Apr 2008
    Tipperary
    Default old pc boot manager gone
    my sisters pc is saying boot manager not found , hard drive is wiped too tried installing win 7 and linux wont load says boot manager not found tried repair on win7 no good , its an old machine pentium4 told her to bin it but cash is a bit tight any fix ??
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Ok couple of things to try.
    1st of is boot sequence in bios.
    2nd hdd priority in bios
    3rd if your doing a full format, then i would set boot priority to 1st cd/dvd and select correct drive. You also want to delete all partitions on the hdd.
    Ensure hdd is seen in bios.
    Boot into setup of windows/linux and check its seen again, format it and let it instal. If you get the same error once rebooted, its your boot sequence.
    TBH i would be thinking of installing windows xp on a P4 setup.
    Run repair console from xp cd and use command fixmbr to repair master boot record
    Apr 2008
    Tipperary
    THANK YOU CUNNY YOU ARE GREAT
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Quote Originally Posted by mtv1 View Post
    Thanks Stig
