Results 1 to 9 of 9
    Default xprog m powersupply
    Hi!
    i have to buy external powersupply 15 v for xprog m
    i the manual they use
    Power Supply
    - universal power provider: 100/240 Vac ? 47/63 Hz/ 15 Vdc ? 300mA;
    i only found 15Vdc - 400 ma on internet can i also use it?
    Yes, sure.
    But make sure that you have negative on the connector outer electrode and positive is in the hole.
    aissa09's Avatar
    Blida Algeria
    Quote Originally Posted by chriskross View Post
    Hi!
    Power Supply
    You can use the 15v supply no problem
    Best regards aissa
    AISSA SERVICE ELECTRONIQUE
    BLIDA car radio decode
    BATLER
    Guest
    my clone device dont work with power supply ,only usb even with TMS374 and everything ok so far...
    DK Veteran gtmech's Avatar
    Hell
    i use the same 15v 400ma power supply for all my programmers and works perfect on them all
    aissa09's Avatar
    Blida Algeria
    Quote Originally Posted by BATLER View Post
    good idea, especially for tms
    Best regards aissa
    aissa09's Avatar
    Blida Algeria
    Default x prog china
    is what XPROG made ***8203;***8203;in china can read 25lc160
    win xp
    thank
    Best regards aissa
    aissa09's Avatar
    Blida Algeria
    someone tries XPROG former model for reading and programming 25lc160
    Best regards aissa
    aissa09's Avatar
    Blida Algeria
    no one has experience
    Best regards aissa
