Page 13 of 33 FirstFirst ... 38910111213141516171823 ... LastLast
Results 181 to 195 of 686
Hybrid View
    Aug 2008
    Quote Originally Posted by M4rcel-H View Post
    i use pli its the best image jade think green i have no problems atall :P
    Are you up and running now then M4rcel-H ?? What was your cure???
    @tahvall
    Thanks, nice post I am sure some will find it very usefull
    @alunfennel
    Thanks for your input to alun, move around a little don't we?
    jbvid
    V.I.P. Member alunfennell's Avatar
    Oct 2008
    Quote Originally Posted by jbvid View Post
    @tahvall
    @alunfennel
    jbvid
    Hi Jbvid,
    Good to see your expertise been shared to a larger audience, we have to move around to keep up with Information especially the way things are going at the moment.
    Kind Regards:
    Alun
    Nov 2008
    Default Jtag 7020
    Can I use the same procedures for 7020?
    Aug 2008
    Quote Originally Posted by wichitl View Post
    No, bootloader is different, I think you will need to google for info, unless anyone can point you in the right direction.
    jbvid
    Nov 2008
    For clone, check the RS232 cable because in my DM500 it was in the wrong side..
    Sorry for my very bad english.
    Oct 2008
    no my dm500 is still broken i dont now but i can watch tv wit my cart no network at all
    Oct 2008
    peope with clone dm500 cabel or sat use the dos jtag it works 100% with a good bootloader
    my dm500 clone is broken network is dead i don't no what it is
    Aug 2008
    I would start to suspect the Asix ethernet port chip. I have read several reports on various forumf of the same symptoms and failure that you describe.
    You could prove your system out by trying a borrowed DM500 on your setup/connection.
    jbvid
    Oct 2008
    my dm 600 en dm 7020 are servers and thats super never hangups hahahaha greate stuff the originals :P
    Aug 2008
    You seem happy, so your'e not bothered about the help given trying to get your dm500 sorted out for network connection, hahahaha?
    jbvid
    Nov 2008
    i have the same probleme whith may dreambox, it's dead
    Can be repair using com port, for the moment i do not have other cable?
    Aug 2008
    Quote Originally Posted by spider_s View Post
    Depends how it died, No, if is a clone and gemini shot it down, Jtag only way to fix, goto link,
    Digital Kaos - Downloads - How to JTAG a DM500
    jbvid
  13. #13
    Oct 2008
    my dm 500 is a test box but it wont work on lan i think my chip is not working annymore i can flas wat i want but nothing helps
  14. #14
    May 2008
    I have jtagged my 500s with dos and windows several times but with dreamup i get
    nothing only bright red light and dim green light.
    Suggestions?
  15. #15
    Oct 2008
    you have the wrong bootloader or not te right tuner version
