Page 21 of 46 FirstFirst ... 11161718192021222324252631 ... LastLast
Results 301 to 315 of 686
  1. #301
    Oct 2008
    my dm 500 is a test box but it wont work on lan i think my chip is not working annymore i can flas wat i want but nothing helps
  2. #302
    May 2008
    I have jtagged my 500s with dos and windows several times but with dreamup i get
    nothing only bright red light and dim green light.
    Suggestions?
  3. #303
    Oct 2008
    you have the wrong bootloader or not te right tuner version
  4. #304
    May 2008
    I have tried philips & alps same result
  5. #305
    Aug 2008
    Quote Originally Posted by targus View Post
    A couple of things to check, have you had a previous succesfull connection with dreamup before with your present Null Modem Cable?
    Also have you tried different versions of dreamup and unticked the network box?
    jbvid
  6. #306
    May 2008
    yes i have tried a lot of dreamups but the only i get once wad com break detected
  7. #307
    Aug 2008
    jbvid
  8. #308
    May 2008
    I have 2x 500s and the other give me never problems with the null modem cable
  9. #309
    Nov 2008
    I am another victim of Adios Amigo
  10. #310
    Aug 2008
    Quote Originally Posted by ihamba View Post
    Well if you will use Gemini on a clone :
    Try the link below to Jtag your box. You may need more constructive posts to access the Downloads Section
    Digital Kaos - Downloads - How to JTAG a DM500
    jbvid
  11. #311
    Oct 2008
    jou got the enigma bomb ?????
  12. #312
    Nov 2008
    Ukraine
    I am also a victim .
    I have two questions about jtag procedure.
    1. Whant kind of cable i need to use? IDE ATA-33 or UDP cat 5e(LAN) or else..
    2. I read on russian forum that it is possible to jtag without microscheme and resistors. IS THAT TRUE?
  13. #313
    Aug 2008
    Quote Originally Posted by smiak View Post
    None of those cables you mention, I think you will be struggling but what you need is a Jtag cable. Read the last link, (Post#377) I keep posting it, is anybody ever reading it???????
    No, to the Russian forum way AFAIK.
    jbvd
  14. #314
    Nov 2008
    Ukraine
    Downloaded that file, but still i dont have a clue what kind of signal cable to use. I think to go to the radio-market and tell them what i am going to do with it and thay will recommend...
    Lots of people say that thay jtaged they boxes "with cable with resistors" - they omitted that they use microschem? or they really used only cable with resistors?
  15. #315
    Aug 2008
    You have not read it properly, read the ((((Intructions.txt)))) it tells you how to make it yourself 25 pin port plug 5 resistors and 6 short lengths of wire.
    jbvid
