Page 24 of 46 FirstFirst ... 14192021222324252627282934 ... LastLast
Results 346 to 360 of 686
  1. #346
    Quote Originally Posted by jbvid View Post
    Are you using a Null modem Cable with Dreamup software to put a new image onto the dm500 ????, (Untick use network) this is the only way after Jtagging in a new bootloader.
    You cannot use FTP to load image.
    If still struggling you could have a hardware problem if no lights on box.
    UPDATE : Try this lot (Attached) for DM500 Cable, it worked on mine
    jbvid
    Fixed, thanks!
    It was that my dell laptop was "to quick", but I could lower the frequency in bios and then the flash went right.
    /perda
  2. #347
    Quick tips for anyone having problems with the DM500 JTAG:
    1. Make sure the JTAG cable is below 10cm in length, I had to shorten mine from around 11cm to 8cm to be sure.
    2. I couldn't get jtag_windows.exe to work at all, but succeeded with JtagDm500.exe which seems less fussy on the timing for the DM500 power on.
    3. Timing of the DM500 power on is critical so get yourself in a postition where you can use a switch to power the unit on, with the switch easily accessible from the computer. I used a switched power extension lead which was perfect. You are going to find it very difficult to get the timing right if you are just plugging the power adapter into a socket or putting the 12v lead in the back of the DM500.
    3. You might need to try several times using JtagDm500.exe, this was my experience:
    • The first time it hung at the "download" stage (100% CPU, no progress)
    • The second & third time it came up with an error at the erase flash stage
    • Forth time was successful, note 100% CPU during the download stage is normal.
    • Download stage took approx 20 mins
    4. Patience is very important, if you aren't getting anywhere and getting frustrated, give up for the day and try again the next day, use the time to recheck and re-examine the JTAG cable, PC settings etc.
    Good luck!!!
  3. #348
    Aug 2008
    @MaryHinge
    Great advice, nice post, good important info. Needs reading by all who have Jtag probs. Even better if it could be put up as a Sticky.
    jbvid
  4. #349
    Oct 2008
    Exclamation 100 % boot Loader Flashed
    Hi for all
    I have flashed the DM500s boot loader successfully, as shown below
    the green light is always on (Solid)
    but the DM500 Doesn't sense any connections Via Null modem Cable, so
    I'm not able to communicate with Dream up and flash new image.
    also what's the connection of the J60 Cable?
    is this right connection ?
    if yes,
    which way it should be ?
    however i have tried many connection , but get failed every time
    i hope that if i can find a solution here.
    thanks in advance.
    Best Regards,
    Fox2005Eng
  5. #350
    Aug 2008
    @fox2005eng
    Not sure if you have done it correctly or used the correct software and connections or at least I am not familiar with this method. Most with success in this thread have used the software/files from the Download section onsite and have not been using the connections & software you have posted and shown in your pictures using a 9 pin port. Not saying it can't be done your way only that many have had success with the Jtagdm500.rar or JtagWin5xxx.zip in the downloads.
    Sorry, never seen the connections shown in your Pics so can't help you. The only one I am familiar with solders 6 wires onto the dreambox Jtag pins and uses a 25pin DB25 connector and 6 resistors on the PC end with a short ribbon cable between.
    A null modem cable needed for dreamup, only three connections needed Pins 2to3, 3to2, 5to5
    jbvid
  6. #351
    Oct 2008
    Exclamation
    @fox2005eng
    jbvid
    thanks mate for ur reply
    i have used jtagwin5xxx with Jtag Connection as shown below
    i know the null cable modem just needs three connection as u mention above
    "2to3, 3to2, 5to5", but my question is; which pins on the dreambox board?
    Thanks in advance
    Best Regards,
    fox2005eng
  8. #353
    Aug 2008
    It doesn't go to any pins on the board.
    Your Null Modem Cable lead goes from the PC's 9 pin com port into the 9pin com port on the back of the DM500. The use Dreamup software make sure 'Use Network' is unticked. Don't plug in or power up the DM untill dreamup S/W tells you to, if it doesn't tell you too then its not connected correctly to the PC (Cable or Com port problem)
    jbvid
  9. #354
    Apr 2008
    HI guys merry christmas to every one, i got a problem with my dream box iv managed to put the boot loader on it with 0_Philips_Tuner and everything went successfull but now im trying to connect my box with dreamup and it saying this message (upload completed waiting for acknowledge) it not going anywhere from there iv even tried a diff null cable and dreamup's but still no luck thanks in advanced.
  10. #355
    Aug 2008
    Quote Originally Posted by sms420 View Post
    Make SURE you have a null modem cable and a PC with a 9 pin com port and read my last post for the correct procedure.
    jbvid
  11. #356
    Apr 2008
    i connected the 9 pin cable to the pc and then the box then i opned the dreamup and clicked on connect then after 5 seconds i powredup the box the dreamup detected the dm 500 and and installed something but its stuck on upload completed waiting for ...... it doesnt move from there
  12. #357
    Aug 2008
    You haven't red this guide then, at the top of the Sticky's????
    http://www.digital-kaos.co.uk/forums...ox-dreamup-33/
    No waiting for 5 secs, wait for '''Connection Prepared now switch on Dreambox'' Try a different version of Dreamup if you don't get that message.
    jbvid
  13. #358
    Apr 2008
    i ok iv read the guide above and tried diffrent dream ups all of them say the same thing im connecting the cables the running dream up then clicking connect and when the dream up says connect your box i then connect the power to the box it says its installing boot loader in the dreamup then hangs at the point where it says upload completed waiting for acknowledge its not moving and the flash button is blanked out i cant click on it to write the image.
  14. #359
    Aug 2008
    Re-read my last post again and tell me if you are getting ''''''Connection Prepared now switch on Dreambox'''' Before you switch it on.????
    If you don't get that message you haven't got a connection due to, either a crap cable ie not a null modem cable or PC com port allocation problems.
    jbvid
  15. #360
    Apr 2008
    yes i get tht message then i connect my box and then dream up loads this flashloader and hangs at upload completed waiting,.........
    i do get the message ''''''Connection Prepared now switch on Dreambox''''
