Page 27 of 46 FirstFirst ... 17222324252627282930313237 ... LastLast
Results 391 to 405 of 686
  1. #391
    Aug 2008
    Quote Originally Posted by dnue View Post
    Hi there
    thanks for your instructions.
    Can`t find the wright delay time.
    Using a Intel Pentium Pro 1600MHZ.
    How long do i have to wait after connecting the Dreambox to start the Programm?
    danny
    There is no set waiting time, the delay time varies, you need to experiment on your own setup. (If all your connections and wiring is ok that is) Read the Instructions text in the 'How to Jtag DM500' in the Downloads section.
    jbvid
  2. #392
    Jan 2009
    bloody hell! I was cheated and bought a clone thinking it was real. Could not tell the difference
  3. #393
    Aug 2008
    Quote Originally Posted by hemojern View Post
    They're all clones now, no new ones made anymore, hope you didn't pay new prices, just don't put Gemini on it, or you'll be back on this Jtag section shouting 'HELP'.
    jbvid
  4. #394
    Jan 2009
    Cool
    how about the 4.31 Version?
    I heard there are no problems.
    Dany
    Do not use any higher version than 4.2 all after that had the bomb virus.
  5. #395
    Aug 2008
    Quote Originally Posted by clavijo3 View Post
    Hay un programa para dm500 jtag por msdos alguien puede decirme donde bajarlo.
    gracias
    Use translation to English and repost it if you need help.
    jbvid
  6. #396
    Jan 2009
    My DM500 was unsuccessfully flashed via lan...
    Now i jtag it via LPT jtag cable, successfully.
    But, i can't flash new firmware. DreamUp detects DM500 and says "initiating flash-loader upload" and freezes...
    What i have to do now?
  7. #397
    Aug 2008
    Quote Originally Posted by Grinja View Post
    I presume you are using Null modem cable for this first flash transfer? (this is a must after jtag)
    A few things to try, another version of dreamup and make sure to (untick) network connection box in dreamup or it will be looking for a Network/Lan connection instead of a Com port rs232 connection.
    Finally try another Null modem cable and a different PC.
    jbvid
  8. #398
    Jan 2009
    Quote Originally Posted by jbvid View Post
    jbvid
    Thanks for reply!
    Yes, i'm using null modem cable, after jtag programmed new bootblock.
    Network couldn't be used because DB firmware was damaged before by unsuccessfull firmware flash.
    But, now i flashed it!
    (Don't know what reason i couldn't flash DB.
    Tryed programm by jtagdb few times - no result - DreamUp hangs on initiate flash.)
    First i run jtagdb500.exe with -X parameter (to erase flash), and after erasing run jtagdb500 do write new bootblock.
    After erasing and new bootblock programming i flashed DB500 by DreamUp and null-modem cable without any problem.
    Now it works
  9. #399
    Feb 2009
    By a faulty uploade , my dreams detect as break one by dream up and story begins ...
    I did search on the net for jtaging on db500 and lots of results ,pointing Me here.
    start Reading whole topic from the first to here ( page 49 & post 486 ). got lots of errores and find my way step by step to bring the clone box to life !
    so I decided to write my experience for those who are patient and eager to know new things . if you are not, its better to buy another box instead wasting your priceless time on a breaked clone box
    Trying to prepare an step by step,pictured guide as soon as possible.
  10. #400
    Aug 2008
    Quote Originally Posted by smehdi View Post
    Did you look in our downloads/dreambox section? ? there is a very good jtag guide already in there which you could have used to save all your troubles, but i'm sure your detailed steps will be helpfull to others.
    jbvid
  11. #401
    Jan 2009
    too hard for me!!
  12. #402
    Feb 2009
    Usa
    Quote Originally Posted by revolte View Post
    i have find other soft to get my dm to work
    the interface is the same
    LPT?????> Dreambox/Clone
    2 ?> 100 ohms ?> 11 ( Halt)
    3 ?> 100 ohms ?> 9 ( Tms )
    4 ?> 100 ohms ?> 7 ( Tck )
    5 ?> 100 ohms ?> 3 ( Tdi )
    11 ?> 100 ohms ?> 1 ( Tdo )
    25 ?????? 16 ( Ground)
    Th pins 18, 19, 20, 21, 22, 23, 24 e 25 of the port LPT must be shunted between themselves.
    the software is attached
    first you connect the cable betwen dm and lpt port then power up the dm
    then open a dos windows and execute the soft and enjoy
    tested by me and work 100%
    the soft name is jtagdm500 so you unzip the folder in c and open dos windows
    c:\cd jtagdm500
    c:\jtagdm500>jtagdm500 -m dm500 -i
    you have some thing like this
    C:\Jtagdm500>jtagdm500 -m dm500 -i
    Dreambox Dm500 board initialize
    Flash info. : INTEL JS28F640J3D75
    [dm500] reading CA:03 ff 07 ff 0f ff 1f ff 3f ff 7f ff ff ff 00 10
    [CA] Ho Ho! CloneWARS corrupted bootloader eh?! consider getting a IPBOX!
    Readed Config Area
    Configuration Area
    Mac Address: 00:09:34:aa:0b:cc
    Redunderant Mac Address: aa:0b:cc
    Tuner Type alps
    tham mean the communication is ok then
    C:\Jtagdm500>jtagdm500 -m dm500 -e 00:09:34:00:11:22 -c
    Readed Config Area
    Configuration Area
    Tuner Type alps
    Mac Address Change Requested
    Commit Config Area
    Configuration Area
    Mac Address: 00:09:34:00:11:22
    Redunderant Mac Address: 00:11:22
    Tuner Type alps
    Erase Flash. done
    Download......19%
    enjoy
    Thanks a lot
  13. #403
    Feb 2009
    can it read the flash ?
  14. #404
    Feb 2009
    Usa
    Hi All,
    I managed with the great help of this forum to bring back to life a dead 500-s with JS intel chip by using the dos program jtagdm500.... Now i have another dm500-s with a TE intel chip and by reading the thread i understand that i need to use the WIndow file. Unfortunately does not want to connect, even with my old P3 - 500 mhz slow computer.. what incredible is that the light is green but wont connect to dream up several diff versions. the cable is ok because with other 500-s will connect immediately... Now my jtag lead is the one with the resistor connected to the lpt... there is no LS245 IC as in jtag.jpg in guide "how to jtag your dm500"... it is this my problem?
    Using the dos version goes to "erase flash done" and then nothing...
    Please help
    In photo attached there is the other dm500-s that i managed to flash but has a weak tuner as in the sat find cannot get more than 35 to 50%... where is the tuner and what can i do to reach 80% please ?
    i just managed by using the windows program and running the antivirus.... i noticed that the delay was a bit longer although fast at 1 sec... managed to connect and write it... now dreamup is connected and flashing the corect image....
    moral of the story a 500 mhz computer it is too fast you need something very slow!!!!!!!!
    Please help me with the one with weak tuner... THANKS
    Damn it! the one i just flashed start now OK with the initial GP blue screen but is black & white then a bit of grey noise then a completely black screen... front light dead and cannot ping the image known IP address.. What did it happen? please look at picture attached with tuner metallic shielded from japan. Please help
  15. #405
    Aug 2008
    Quote Originally Posted by mark1832 View Post
    Hi All,
    Please help
    After jtag why not try flashing a different image instead of a Gemini one with dreamup, there are better images. Never seen a DM500S without a visual (tin box) type tuner so don't think there will be much you can do to improve its strength. Are you sure you are lined /set up to the Sat correctly with the weak tuner box?? and your cabling is good??
    jbvid
