Page 28 of 46 FirstFirst ... 18232425262728293031323338 ... LastLast
Results 406 to 420 of 686
  1. #406
    V.I.P. Member alunfennell's Avatar
    Oct 2008
    If anybody is interested this is where to buy all your clone models
    h++p://www.alibaba.com/trade/search?SearchText=dreambox&Country=&CatId=0&IndexA rea=product_en&ssk=y
    Regards:
    Alun
  2. #407
    Feb 2009
    Usa
    Quote Originally Posted by jbvid View Post
    After jtag why not try flashing a different image instead of a Gemini one with dreamup, there are better images. Never seen a DM500S without a visual (tin box) type tuner so don't think there will be much you can do to improve its strength. Are you sure you are lined /set up to the Sat correctly with the weak tuner box?? and your cabling is good??
    jbvid
    Many thanks for your prompt reply JBVID... cabling and setting is ok as other 2 dm500s have signal at over 80%... it is just a weak tuner that with my incredubility look like does not exist but 1 of the other two is the same and work at 90% signal.... Yes i have flashed sfteam images but same problem start with the sfteam initial screen in B/W and then i couple of grey noisy then black screen... no light and cannot ping.... only noticed that 2 light of network are steady on but there is no3rd flashing light.. I feel is a problem with the video output... does anyone know which IC control the video output please ?
  3. #408
    Aug 2008
    @mark1832
    Can't help much on the internals of the faulty tuner box, may be time to think about a replacement if you need 2 or 3 good working ones, take a look at the post by Alun above, the clones are cheap enough.
    jbvid
  4. #409
    Aug 2008
    @daiaaz and razorx
    You both need a few contructive posts (ie helpfull, and usefull information to others on site), a bit of give and then take, to be able to access the download section, not hello, or my name is fred.
    jbvid
  5. #410
    Feb 2009
    ive seen again mine flash and its an JS28F640 so i can flash with DOS flash
    but now i can not flash it says INTEL Unknown
    and stops after Erase Flash Done
    and i cant do nothing more plz HELP!
    plz help guys
  6. #411
    Aug 2008
    Quote Originally Posted by marcelo View Post
    plz help guys
    Why not try the 'jtagwin5xxx' (Windows version) in the downloads section??
    jbvid
  7. #412
    Feb 2009
    because i cant get connection with him =/
    ive tried so much times and never getted connection
    some guy on other forum said to me, to disconnect the ground when the program stops at
    Erase Flash Done
    and then reconnect
    lets see what will happen tomorow i will test that
  8. #413
    Aug 2008
    Erase Flash Done
    and then reconnect
    You should be able to get a connection if you keep trying different delay times or try it on another PC.
    jbvid
  9. #414
    Feb 2009
    Usa
    Erase Flash Done
    and then reconnect
    Marcelo, it is enough to read my post....
    like you, i could not connect with windows program and then what i did? i read 34 post and that gave me the solution as naother bloke suggetsted..... My p3 500mhz was too fast!!!!!. I run the antivirus which slowed down the pc and connected straight away... it would be better if you have a 166mhz pc!
    SO what are u waiting for! ??
  10. #415
    Feb 2009
    HI guys i have a dream 500s its bootloader was dead i manage to get the restore the boot loader with the jtag but now i have a problem connect the box to the dream up. this is what im doing and step 6 whats happening. its getting stuck it should go to step 7 and let me flash the image. if any one can help please i be thank full to you all.
    1, i connect the cable
    2, i click the connect button on the dreamup
    3, the dream up says connection prepared connect the box
    4, then i power up my box
    5, then the dream up sasy uploading flash loader,
    6, the status bar show its done at the bottom of tht status bar it says " upload completed waiting for acknowledge"
    7, Dreamup should say box attached and ready and the flash button will also be ready to use but this never happens it gets stuck at step 6
    the dream up gets stuk just before the message "box attached and ready" i cant click on the button where it says flash the dream up does not go to the point
  11. #416
    caveman_nige's Avatar
    Feb 2008
    In my Cave
    what cable are you using this time mate...? I think you need to use a null modem cable now..
  12. #417
    Feb 2009
    Quote Originally Posted by caveman_nige View Post
    i used a null modem cable for dreamup many times and not found any problem.
    i just found a problem first time.
  13. #418
    Aug 2008
    Quote Originally Posted by kikjung View Post
    Try a different null modem cable, then another PC, you are not getting a ''connection'' to send data to dreambox , hence 'waiting for acknowledgement'.
    You could first make sure correct com port selection is active in Device manager and same as dreamups, and try different versions of Dreamup
    jbvid
  14. #419
    Feb 2009
    Usa
    i was you kikjung i would try on another dm500s, then pc, then cable, etc ... until u find where the problem is
  15. #420
    Feb 2009
    Hi guys. I have a dm500s clone and today i had a real surprise : there is no jtag connector as u can see
    I appreciate any help that you may offer.
    regards
