Page 3 of 46 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 686
  1. #31
    Newbie revolte's Avatar
    Apr 2008
    Exclamation
    I've got mine to work and flash OK, but now the box is recognized as DM56** and no video any suggestions
  2. #32
    Apr 2008
    Omar,
    I tried your method, hooked up the jumper then switched to the next set and it still didn't connect, guess it's a dead dm 500.
    Although when I do hit connect with it hooked up to a jtag it does make the red light come on.
    It just can't be dead... time to get more determined,
  3. #33
    Apr 2008
    [quote=revolte;12763]I've got mine to work and flash OK, but now the box is recognized as DM56** and no video any suggestion
    use dream up
    http://www.dmm-tv.com/downloads/rel109-20060803.img
  4. #34
    Apr 2008
    Quote Originally Posted by fireman1374 View Post
    Omar,
    (Although when I do hit connect with it hooked up to a jtag it does make the red light come on.)
    good ..now download firmware
    try many time
  5. #35
    Apr 2008
    Dear Omar,
    Ok Will The Bootloader Fixed If Upgraded With rel109-20060803.img This Image.
    Thanks.
  6. #36
    Apr 2008
    Quote Originally Posted by omar View Post
    not working with windows vista
    Omar what you mean by change the jumper
  7. #37
    Apr 2008
    See the Jumper here,
    This was quoted earlier.
  8. #38
    Apr 2008
    I Think It's Not Suitable For All Models.
  9. #39
    Apr 2008
    Can anyone get the philips bootloader to work
  10. #40
    Apr 2008
    When I use the Alps one it boots and allows me to install the new image, but the option to search for new channels in the menu is missing.
  11. #41
    Apr 2008
    Quote Originally Posted by Greystoke View Post
    the philips bootloader ... ok
  12. #42
    Apr 2008
    must use philips bootloader
  13. #43
    Apr 2008
    When I Jtag with the philips bootloader, I get no lights after the Jtag is done.
  14. #44
    Apr 2008
    Wink
    i have find other soft to get my dm to work
    the interface is the same
    LPT?????> Dreambox/Clone
    2 ?> 100 ohms ?> 11 ( Halt)
    3 ?> 100 ohms ?> 9 ( Tms )
    4 ?> 100 ohms ?> 7 ( Tck )
    5 ?> 100 ohms ?> 3 ( Tdi )
    11 ?> 100 ohms ?> 1 ( Tdo )
    25 ?????? 16 ( Ground)
    Th pins 18, 19, 20, 21, 22, 23, 24 e 25 of the port LPT must be shunted between themselves.
    the software is attached
    first you connect the cable betwen dm and lpt port then power up the dm
    then open a dos windows and execute the soft and enjoy
    tested by me and work 100%
    the soft name is jtagdm500 so you unzip the folder in c and open dos windows
    c:\cd jtagdm500
    c:\jtagdm500>jtagdm500 -m dm500 -i
    you have some thing like this
    C:\Jtagdm500>jtagdm500 -m dm500 -i
    Dreambox Dm500 board initialize
    Flash info. : INTEL JS28F640J3D75
    [dm500] reading CA:03 ff 07 ff 0f ff 1f ff 3f ff 7f ff ff ff 00 10
    [CA] Ho Ho! CloneWARS corrupted bootloader eh?! consider getting a IPBOX!
    Readed Config Area
    Configuration Area
    Mac Address: 00:09:34:aa:0b:cc
    Redunderant Mac Address: aa:0b:cc
    Tuner Type alps
    tham mean the communication is ok then
    C:\Jtagdm500>jtagdm500 -m dm500 -e 00:09:34:00:11:22 -c
    Readed Config Area
    Configuration Area
    Tuner Type alps
    Mac Address Change Requested
    Commit Config Area
    Configuration Area
    Mac Address: 00:09:34:00:11:22
    Redunderant Mac Address: 00:11:22
    Tuner Type alps
    Erase Flash. done
    Download......19%
    enjoy
  15. #45
    Apr 2008
    Default remove jumper
    Quote Originally Posted by innerman70 View Post
    I remove the DB 25 pin and the other connection then connect null cable tried dream -up and got nothing from the DM 500 C it's still dead
