any reason why the dm500 jtag files dont seem to open and connect via the connected jtag
I have a problem with jtag dm500s
G:\JTAG_DM500_AiO>jtagdm500 -m dm500 -e 00:09:34:01:A4:3F
Dreambox Dm500 board initialize
Flash info. : INTEL Unknown
[dm500] reading CA:ca 00 01 06 20 ff 11 00 09 34 20 ff 1e 06 04 ff
[CA] 6th mac addr byte is not redunderant, fixing it
Readed Config Area
Configuration Area
Mac Address: 00:09:34:20:ff:11
Redunderant Mac Address: 20:ff:11
Tuner Type alps
Mac Address Change Requested
Commit Config Area
Configuration Area
Mac Address: 00:09:34:01:a4:3f
Redunderant Mac Address: 01:a4:3f
Tuner Type alps
Erase Flash done
Hi. I am trying to jtag using DOS but cannot connect. I guess my CPU is version2 which I have to solder the wire to the CPU port.
Where can I download the windows version?
when i open cmd dos is open but when i open 1info.bat or other command my system is stop working ans there is fault in programe i have win 7
bougt a used dm500 didn?t know it was a clone.
I?ve bricked it in half an hour, will test this guide.
Hi all,
I have a death board with INTEL TE28F640 flash and i was intend to use windows version of JTAG as some ppl. are write above. The JTAG is a simple one with 5 100ohm resistors and is OK because if i use the DOS verssion the board is recognized but unknown INTEL flash message appear. So the problem is when i start the windows program with the right blimg inside it connect to the board and memory but when i click write the program it close by itself. Is this because the CPU (i have a Intel 2GHz Pentium Dual Core E2180). What i can do ? Thank you !
i try to use windows but alway windowsjtag crash
dont know what to do
help please
Just bought myself a soldering iron....here goes! Thanks for the guide!
Hi all,
I have read the thread and successfully created a JTAG cable as outlined in the tutorial. When running file 1info.bat all i get is
Register Test Failed. Check Cable connection.
Target Test Failed. If you need help, run "flash help"
Please assist as my DM needs to be JTAG as i have no visible lights when power is plugged in.
can anyone pls tell me how are the wires connected to null modem for dreambox 500s ?
i bought a null modem.. but i get no connection with dreamup...and i tryed EVERYTHING
pls help
Does anyone know if there is a source code for the DM500 JTAGing? I mean the source code that recovers DM500 that has a faulty bootloader.I found only compiled version.
