Page 43 of 46 FirstFirst ... 33383940414243444546 LastLast
Results 631 to 645 of 686
  1. #631
    Feb 2012
    can I use windows 7 for flasing 28f640 ?
  2. #632
    Feb 2012
    Default jtag help
    i tried jtag my dreambox dm500-c but it is still shutting down and not comunicating with pc
  3. #633
    Feb 2012
    i have gone throught the whole post here... i have a dm518s which is like the dm500s i have the TE28F640 flash chip, im assuming i need the windows version of the jtag tool. overall i have done this and still no comms with dream up... i know dream up and null modem cable works as i have flashed another box at the same time. any thoughts?
  4. #634
    Mar 2012
    Quote Originally Posted by Devilfish View Post
    There's now a guide, pictures and all the tools you need to JTAG your DM500.
    You will need these tools if your clone has been zapped by the Gemini 4.3.1 image.
    Untested by myself, don't use Gemini .
    Njoy!
    How to JTAG a DM500
    Digital Kaos
    thx a loot man
  5. #635
    Apr 2012
    USB LPT? J-TAG
  6. #636
    Apr 2012
    DM500 clone the COM port does not work I changed the MAX232??
  7. #637
    DK Veteran jatrophaseed's Avatar
    Fujian, LongYan
    soryy wrong post.
  8. #638
    unreal1024
    Guest
    Default JTAG inetbox 300s
    Hello, please, JTAG for DM500S and INETBOX300S is different?
    Thanks!
  9. #639
    Mar 2011
    hi , nice work
  10. #640
    May 2012
    Quote Originally Posted by dream_box View Post
    There is the answer for you, from other forum!:
    "The clone maker would have routed the other pins out because of R600-R603 pullups but as output pin 20 needs no pullup they probably left it unrouted. In which case you'll be SOL. Even with precise drilling it's near impossible to get at unrouted BGA balls without wrecking the board, because of the power planes.
    Dream JTAG won't work without a connection to processor pin 20. I'd say you're stuck with a brick. The only way to save it is probably to desolder and replace the flash memory with a newly programmed chip, which of course requires SMD rework equipment not to mention a fair bit of time. Not economic. Those clones weren't meant to be recovered."
    Good luck!
    Thanks.... I will try another method
  11. #641
    May 2012
    Is it possible with a serial port instead of the 25-pin thingy? Got a new modern computer ..
  12. #642
    Fujian, LongYan
    Quote Originally Posted by Bustamove View Post
    I doubt, the speed may not b there. How about try using a usbjtag, it proven to be ok. I hv tested them. The latest is usbjtagnt. FW provided by their forum. Caution, some Anti-virus detect their FW as trojan, to use them, u may hv to disable the Anti-virus SW for that period of time. Try google usbjtag u may find their site and a u-tube tut was provided too.
  13. #643
    May 2012
    Quote Originally Posted by jatrophaseed View Post
    What about this? Seems simple enough. May be a bit too slow with USB->Serial but it is wort a shot.
  14. #644
    Fujian, LongYan
    I doubt. No harm trying.
    My present solution to BL and corrupted flash is: replace the flash. I hv all the tools. UP-2008, hot-blower, clips and liquid flux etc. <5min blow job... hehehe....
  15. #645
    May 2012
    What did my link disappear?
    hxxp://marsohod.org/index.php/ourblog/11-blog/163-marsblaster
    google translate is needed.
    Well all important inputs are covered. (tdi,tck,tms,tdo)
    Don't know if it can connect to DB? Maybe it needs a special connection handshake or something. I have no idea.
    Edit: The MarsBlaster only takes "max2 cpld" .SVF files, which means it doesnt work? Or can i convert a DB .bin to .svf somehow? It's just binary data isnt it?
