Results 16 to 30 of 45
  1. #16
    Quote Originally Posted by lidons View Post
    files you have V33,01.
    the new v34, have it.
    Quote Originally Posted by jokersat View Post
    i have version 33 dumps not v34
    guessing no
  2. #17
    morocco/fbs
    For All Members who have SBB clone , Dont Try to update it with V34
    i test the update V34 for 10 times and no way my SBB lost firmware so , silca know what to do , note eprom still the same no error found
    ic u3 and U3 will be modifed when you update it = SBB broken
    so be carfull
  3. #18
    kautuvera's Avatar
    What kind of programmer should read and write data on 29f016TI flash memory used?
  4. #19
    morocco/fbs
    like Labtool 48 and xp + beeprog + any programmer have 48 pin adapter
  5. #20
    [QUOTE=jokersat;1023216]
    QUOTE]
    Can you please share V34 files?
    Thank you
  6. #21
    Default SBB Update
    Hello guys,
    Does anyone know what version (and where to download) to update the SBB's China can get PIN code tags below:
    PIN Code Service
    1 - Hyundai PIN CODE
    2 - PIN CODE KIA
    3 - CODE BCM NISS
    4 - VAG PIN CODE
    VAG 4.7 5-PIN
    6 - PIN CODE GM
    Tks for all.
  7. #22
    ray-ray's Avatar
    update will not happen,if you open your unit up missing hardware.(max232,serial not connected)
  8. #23
    If anyone have the file i will try update. I'm not update by rs232. I will update by eprom.
    Anyone have dump file work pin code for GM ?
    Tks for all
  9. #24
    ray-ray's Avatar
    if you understand the board lay out ,it reacts the same way.(BOMB!) on the new boards "the china" they remove the serial eeprom 8 leg . that mean china figure out the serial and password location and was able to twick it in the software.(and that created bugs to the oem code)the bomb see that in it code and starts to erase itself.the early version sbb also has a weak leak that can be detected in the oem code. but not to fear ,there room in the processor to pig back and take a look at the hand shake between "know" processor and the only 1 unknow proceesor that has the secret . ching ching
  10. #25
    May 2011
    Quote Originally Posted by gojko View Post
    New update is available
    (If you have SBB key programmer, download and use it new update)
    you're so nice!
  11. #26
    Meat-Head's Avatar
    Quote Originally Posted by ray-ray View Post
    Coo, could you say that again please, but a little slower and more clearly for thick members.
  12. #27
    ray-ray's Avatar
    i can see what is going on with the upgrade on a factory tko,and then i can compare it to the clone. then you can find the bomb and remove it or disable it ,problem solve.but the big picture is looking at the bus commands,to see what is happening inside . i want to know how there protcal works on the differant model cars.
  13. #28
    Newbie dinson's Avatar
    when i update u3, u4 and atmel (leg7up and connected to leg8)
    i get illegal software error , and some more errors.
    the flash dumps are the same, nothing changes
    any ideas whats the problem ????
  14. #29
    Hollywood
    Quote Originally Posted by dinson View Post
    đđĐđß$đĐßđßđßđđääđłldkf>>;*;ßßߤߤ;>>;>ßߤ]$ß$÷÷×ßß]¤¤¤]ß$$[ß[¤ĐĐß[ß...
  15. #30
    Apr 2011
    SBB Version 33.02
  16. The Following 6 Users Say Thank You to INJECTMDS For This Useful Post:
    elec (2nd November, 2017), Fabian Luque (24th December, 2016), hassan77h (18th August, 2016), jurik8 (10th August, 2018), olegas (1st January, 2016), Talleresmalaga (2nd November, 2018)
