FAP/DPf volvo V50 sid803 problem
Results 1 to 15 of 20
    DK Veteran barti122's Avatar
    Poland N
    27
    Default FAP/DPf volvo V50 sid803 problem
    Hallo i have car Volvo V50 2.0 Diesel ecu siemens sid 803
    Ecusafe v 1.9 not work
    Please remove Fap ecusafe 2.0
    pass to pm
    report please
    Poland N
    27
    hello
    FAP is a problem with it is removed but in spite of what 270km load firing FAPA. As it can be removed
    15
    Quote Originally Posted by barti122 View Post
    hello
    if you have diagnostic then enter in injection ECU and Throw values ***8203;***8203;of the level of additives on the zero.
    Poland N
    27
    and to what equipment is needed. I do not have the equipment to the Volvo. i have pp2000 and kts570 whether this is do not give advice or
    Jan 2011
    i guys i ve the same car and the same problem.do you need a flash or mpc for delete fap?do you have ecusafe 2?i ve problem with mercedes!!!thanks
    world wide
    Default try
    try and report... it is mod with ecusafe 2.0
    15
    hi guys i have this same problem with volvo v50 sid 803 i need DPF off ecusafe not work
    15
    Quote Originally Posted by cezarycezary8 View Post
    post MPC555 dump here
    4
    What tool you use to read flash volvo sid 803 ?
    Quote Originally Posted by adam12112 View Post
    Only BDM. OBD tool not read MPC555.
    Nov 2011
    friend and friend
    89
    Default fap sid803 off
    Quote Originally Posted by yas200979 View Post
    hi good evening please fap off I want to please someone can do it for me thanks
    sid803
    5ws40281a-t
    sw:9658344580
    hd:9655041480
    read original
  13. #13
    Poland N
    27
    try this fap off write only mpc
  14. #14
    Nov 2011
    friend and friend
    89
    Default 307 fap off help, help
    file does not give the same error, help, help
  15. #15
    Poland N
    27
    what is the error. 0000 Error Unknown
