Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Hybrid View
    barti122's Avatar
    Nov 2009
    Poland N
    Default FAP/DPf volvo V50 sid803 problem
    Hallo i have car Volvo V50 2.0 Diesel ecu siemens sid 803
    Ecusafe v 1.9 not work
    Please remove Fap ecusafe 2.0
    Nov 2009
    Poland
    pass to pm
    report please
    barti122's Avatar
    Nov 2009
    Poland N
    hello
    FAP is a problem with it is removed but in spite of what 270km load firing FAPA. As it can be removed
    Jun 2010
    Quote Originally Posted by barti122 View Post
    hello
    if you have diagnostic then enter in injection ECU and Throw values ***8203;***8203;of the level of additives on the zero.
    barti122's Avatar
    Nov 2009
    Poland N
    and to what equipment is needed. I do not have the equipment to the Volvo. i have pp2000 and kts570 whether this is do not give advice or
    Jan 2011
    i guys i ve the same car and the same problem.do you need a flash or mpc for delete fap?do you have ecusafe 2?i ve problem with mercedes!!!thanks
    world wide
    Default try
    try and report... it is mod with ecusafe 2.0
    Jan 2010
    hi guys i have this same problem with volvo v50 sid 803 i need DPF off ecusafe not work
    Jun 2010
    Quote Originally Posted by cezarycezary8 View Post
    post MPC555 dump here
    Jun 2010
    What tool you use to read flash volvo sid 803 ?
  11. #11
    Dec 2009
    Quote Originally Posted by adam12112 View Post
    Only BDM. OBD tool not read MPC555.
  12. #12
    Nov 2011
    friend and friend
    Default fap sid803 off
    Quote Originally Posted by yas200979 View Post
    hi good evening please fap off I want to please someone can do it for me thanks
    sid803
    5ws40281a-t
    sw:9658344580
    hd:9655041480
    read original
  13. The Following User Says Thank You to arvedo For This Useful Post:
    MSDIAGNOSTIC (27th August, 2022)
  14. #13
    barti122's Avatar
    Nov 2009
    Poland N
    try this fap off write only mpc
  15. #14
    Nov 2011
    friend and friend
    Default 307 fap off help, help
    file does not give the same error, help, help
  16. #15
    barti122's Avatar
    Nov 2009
    Poland N
    what is the error. 0000 Error Unknown
