The problem is that u need it to license it through AGCO because the EDT needs to connect to the AGCO server to update software and license, every now and then.
Hello All,
Please help with key for AGCO EDT, a link to software:
http://rapidshare.com/files/453192282/EDT.iso
Thank you very much for your help!
Ok how do you keep the license from expiring?
This is the problem, I do not have a license. But updates are posted automatically. Last Updated 54A.
http://rapidshare.com/files/453216635/54A.part1.rar
http://rapidshare.com/files/453217965/54A.part2.rar
http://rapidshare.com/files/453217534/54A.part3.rar
Mikhail, clean your box in PM, I can not write you in PM!
I know how have Updates of EDT !
Yes please re up the software, thanks
Please press thanks and + rep if i could help a little....
Mikhail, can you please reupload this software again? The link is dead
Best regards. DC
I like to know if we can edit parameters, like turn adblue/scr off with wintest?
Hi. There is no abilty to change parameters like SCR from diagnostic tools. You can change speedlimiters in gearbox ECU. Second limiter is inside flash, but main is in gearbox
br
Hello everyone!
I am wondering if i could use Wintest Software but without AGCO EDT? I'm about to buy a tester (Multidiag) for cars, trucks and some farm machinery.
As seller said, this tester works with opus, autocom and wurth, but with farm machinery there is only Generic OBD fault codes read available with attached software. Is it possible to connect my MF6255 tractor's CAN-bus by single cables to OBD2 with this tester and run this Wintest Software which is available to buy for example on Ali? Is it possible that it will work or to make it work?
