I can use 88890020 interface with VIDA?
I can select in interface list but I don't have OBD cable to try
Maybe pinout for 88890020?
Thank you!
and some help to work VIDA with AVDI ?
I can't communicate with any car
Thank you!
Please go to Movimento Group and download Puma2 manula. There you can find Pinout for 88890020..
88890020 have j2534 support but is away from stable working with Vida / HDS / Techstream
You can try..
Thank you for info
I found pinout but I can't communicate with car
I will try again next week
Any new info?
nothing yet
I can't communicate
any idea ?
Does Vida recognise your diagnostic tool ? If not you cannot use it, you have to change drivers with DICE drivers (if it can be done) or with Actia PassThru+XS .
I can select 888.... from list
You should try in software mode, select a car and then go in software menu, click ADVANCED and then select different ECU`s, if it can read P/N it means that it works only in software mode not in diagnostic mode, just like Actia Passthru +XS J2534-1.
Step by step video, how to use VIDA in software programing mode . Just select Volvo videos.
http://www.drewtech.com/products/cardaqplus.html
Hello
Where can i buy volvo 88890020 but with the best price?
How much it?
Here in Per? only interface+cable usb are $1500 USA dollars.
Thanks for all
Clone Dice 150-180 USD
OEM Dice 550.00-1300.00 USD
Just Depends how your buying level is.
Dealer Code to contacts ..
Those are some of the figures I have seen ..
And NO , I don't sell any , Im an end user.
VG
