OPCOM X17DTL diagnose
Results 1 to 4 of 4
    Senior Member makadam's Avatar
    Nov 2010
    EUROPE
    87
    Downloads
    6
    Uploads
    Default OPCOM X17DTL diagnose
    I just buy OPCOM (chinesse clone with 1.39 firmware) and using OPCOM081016_EN software but there is some problem when trying to connect to body module (instrument, airbag, engine coolant, central door locking) on ASTRA G 1999 X17DTL.After some time there is a message>
    Changing Init Address....!
    The same unit with the same software works without problem to the same module on X12 ASTRA G 1998.
    OPCOM use pin12 for communication to this module.
    Also I cant diagnose VP44 pump in the same car (PSG5).
    I also try to use another software version 090820b with the same result and with this version the unit doesn't work in X12 Astra when using body instrument module.
    Can someone tell me what is the problem with that car?
    BTW Engine diagnostic works fine!
    Downloads
    Uploads
    VP pump you cannot read (16 pin diagnose connector not work)
    You have to connect the interface on pump connector wire (pin 9)
    Nov 2010
    EUROPE
    87
    Downloads
    6
    Uploads
    The problem is when I try to connect to pin12 KW82 the message appears Changing Init address....!
    Somewhwre I read that I must chenge some resistor on the interface v3.
    Nov 2010
    EUROPE
    87
    Downloads
    6
    Uploads
    Just want to confirm that replacing R32 10k resistor with 510 ohm resistor resolve the problem connecting OPCOM V3 (yellow plate) using KW82 protocol and pin 12 on Astra G 1999 X17DTL
