Results 1 to 7 of 7
    Dec 2010
    Default Help on istallation
    ITGate TGM220 with sat card
    Checked signal with existing SLY box. Incoming signal great
    Flashed UR v.8 Ireland
    Selected tv system pal
    Selected English language
    Saved GMT Timezone
    Selected No DiSEqc
    defaulted to Astra 19E
    Selected eurobird/astra 28.2E
    Done transponder scan - scanned 909 services and 118 transponders -
    Found 72 new transponders
    645 New TV services
    84 new radio stations
    180 new data services ??
    pressed setup. expert set up,communication
    IP 192.168.1.24 DHCP checked (I have this set as static IP on ITGATE)
    255.255.255.0
    :LAN
    Nameserver and Gateway 192.168.1.1
    Enabled Network checked Port :80
    Mac address (OK)
    clicked save
    Set up LAN DYNDNS
    user: Damixa
    Pass: OK
    Alias: Damixa
    domain: dyndns.org
    Selected retreive internet IP - No connection available , check connections
    (This gave me an IP and said was OK when I flashed with v9, although would still not download or connect to the internet)
    Changed ITGATE password.
    FTP OK
    uploaded new SLY channel bouquet -
    rebooted
    system then seen all channels but played only FTA channels
    Placed extra url and cccam_2.1.4_full.tar.gz into tmp folder.
    Chmoded both 755
    pressed blue button twice addon manager
    selected manual (yellow)
    selected cccam_2.1.4_full.tar.gz to install
    Installed cccam_2.1.4_full.tar.gz
    rebooted
    Default softcam is Hypercan (IRE)
    Cannot select cccam 2.14 as default softcam
    rebooted
    Can see only 2 softcams "Hypercam [IRE]" and "Commom Interface" channels
    So I can see FTA, cannot select cccam 214 but can see config file in var/etc
    Questions are many, but mainly....to see more than FTA Do I need only a c-line in the config file? Where can I get a cline to test this installation. I have tried on several forums but noone has replied. Am I asking the wrong question/s? and why wont my box connect to the internet? I can FTP into it and my dyndns at damixa.dyndns.org works fine and can view with VLC.
    Help!
    Thanks in advance?
    plasterer's Avatar
    Jun 2008
    Mersyside
    Google card sharing servers mate and take it from there .
    The panel is down for downloads ,so thats out
    Check out the last few posts in this thread mate .................Paul
    PAUL
    Dec 2010
    ITs not just the card sharing, thats not the most of my problems. Its the cccam install. I unzip the tar file in the temp folder it appears in my addons and yet it does not appear in my softcams download, only two appear.
    Also the config file isnt placed into the var/etc file, so I cannot edit anmd enter a cline.
    I now have a 24 hr cline and time is fast running out for a resolution to this, if you can help in any wau I would be really grateful.
    Hope you can
    Damixa
    Quote Originally Posted by plasterer View Post
    plasterer's Avatar
    Jun 2008
    Mersyside
    pm us your mail addy and ile post you
    the var folder from uk ur 9
    Transfer the contents ,(overwrite yours)
    And the cam should then be installed
    Check the attributes
    Amend the CCcam.cfg
    And it will then clear all..............Paul
    Check your mail box now mate
    PAUL
    Dec 2010
    Default Problem Solved with ITGATE
    Ok so I fixed it with the help of the guys from this forum....thanks (PLASTERER).
    Heres what I did, to get my ITGATE TGM working.
    All of the above in the first post in this thread.
    NOTE:
    Since the post above I have flashed V8 over V9
    With V8 flashed I still get an error message "cannot retrieve IP" ,BUT I can load CCCam 2.14, and its visible and selectable when I view softcams.
    With v9 installed I couldnt load cccam 2.14 , but it retrieved an IP address for me.
    Either way , for me, it dont seem to matter, I can FTP, and my alias at DYNDNS.org can see it, so with VLC installed I can play the TV on my laptop. Sorted.
    To begin with , I asked for and received a test cline from CARDSHARING CCCAM SERVER - 30 Hour Free Test ! 5 Day Guarantee !
    I was then mailed a VAR folder from a member on this site and this seemed to sort out most of the problems. I did a factory reset on V8, I selected PAL, then English, then disc (I have one LNB) the went to scan. It defaulted to ASTRA 19E , this was no good for me and I selected Astra 28E , this works fine for me. After the scan had finished , I uploaded a sly bouquet I had downloaded earlier from this site, I used DreamEdit to upload the bouquet to the ITGate. Then I copied the Var folder I had received in the mail and copied it over my VAR folder. I rebooted the ITGATE.
    Then I FTP'd into the ITGATE , I use FireZilla, opened the cccam.cfg file in Var/etc folder and copied the cline sent to me by cccam-server.com, I chmodded this file 755 and also (DONT FORGET AS ITS CRITICAL) chmodded the cccam file in VAR/BIN, after I did all of the above it worked and still does!
    BIG shoutout to this forum and to PLASTERER, without whom I would still be stabbing my eyeballs and screaming at the wife and kids!!
    Im no expert, but if I can help anyone clarify the above, please give me a shout!
    DaMixa
    plasterer's Avatar
    Jun 2008
    Mersyside
    Good work mate
    Nice to leave good feedback to help others as well
    Glad your up and running mate ..............Paul
    PAUL
    Dec 2010
    Ooops!! thanked the wrong guy....I meant to thank you, PLASTERER ...thanks for all your help. Changed the thread above.
    Good work mate
