Page 68 of 132 FirstFirst ... 1858636465666768697071727378118 ... LastLast
Results 1,006 to 1,020 of 1980
  1. #1006
    Jan 2016
    Jumping Around the globe
    I have posted a dump earlier and it wasnt a good read aparently.
    here is my second trial, i am reading with carprog.
    if its not good can you let me know if i can read it with vvdi prog?
  2. #1007
    Oct 2013
    Ukraine
    Quote Originally Posted by Locker View Post
    Hi.
    Try..........2194
  3. The Following 6 Users Say Thank You to masterskay62 For This Useful Post:
    budata (13th July, 2020), Locker (14th July, 2020), momogsm (13th July, 2020), REZON (29th July, 2020), SIRKVA (13th July, 2020), smoggy (13th July, 2020)
  4. #1008
    Jul 2020
    Hi.
    I have VWZ1Z7 (1K0 035 198 B) and I've tried to read FIS using the method from this article.
    As I know the 20, 40, 60 lines of a dump must be the same. But I had only about 1 second after pushing on the "on/off" button for reading and each time i've received different data. Also i've tried to lower the voltage to 7.5v. But in this way the mfd2 just has been switched off.
    I've found some information and now I'm not sure about the right connection. Should I connect 5v instead of GND to the point 3?Connection.jpg
  5. #1009
    carradio2001's Avatar
    France
    Dumps not good ! Trying what say here -->
    Carradio2001.
  6. #1010
    Jul 2020
    Quote Originally Posted by carradio2001 View Post
    Carradio2001.
    I don't have A4 cable. I've used a CH341A programmer and the connection scheme according to the picture. read.jpg
    As it's already been said, I'm not sure about the right connection. Should I connect 5v instead of GND to the point 3?
  7. #1011
    Nov 2013
    Macedonia
    Quote Originally Posted by ArtemK View Post
    Did you connect GND from programmer to radio board?
  8. The Following 2 Users Say Thank You to Zann For This Useful Post:
    irfa (14th July, 2020), masterskay62 (13th July, 2020)
  9. #1012
    Jul 2020
    Also I've found this picture. Where is the true?
    Sorry, I forgot that I had checked the contact 3 on the board by a tester. Definitely it's GND.
  10. #1013
    Nov 2013
    Macedonia
    Do not connect 5V. Connect 3 x 12V to radio factory connector.
  11. The Following 3 Users Say Thank You to Zann For This Useful Post:
    ArtemK (13th July, 2020), irfa (14th July, 2020), shooting (13th July, 2020)
  12. #1014
    Jul 2020
    Hi.
    Eventually I've read the FIS. My problem was that I've used too long wires for I2C.
    Please, help me with decoding.
  13. #1015
    Oct 2013
    Ukraine
    Hi.
    Hi.
    Try........0023
  14. The Following 4 Users Say Thank You to masterskay62 For This Useful Post:
    ArtemK (14th July, 2020), irfa (14th July, 2020), REZON (14th July, 2020), SIRKVA (14th July, 2020)
  15. #1016
    Jul 2020
    Quote Originally Posted by masterskay62 View Post
    Hi.
    Try........0023
    This code doesn't work.
  16. #1017
    SIRKVA's Avatar
    Oct 2017
    BRAZIL
    instal radio in the car
  17. #1018
    nelutzul40's Avatar
    Dec 2011
    Ialomita- RO-
    Try 0823...................
  18. The Following 7 Users Say Thank You to nelutzul40 For This Useful Post:
    ArtemK (14th July, 2020), carradio2001 (14th July, 2020), Dekster (14th July, 2020), irfa (14th July, 2020), masterskay62 (14th July, 2020), smoggy (14th July, 2020), sonices (14th July, 2020)
  19. #1019
    WALES
    Code 100% 0823 .. not possible to be 0023
    wbr
  20. The Following 3 Users Say Thank You to shooting For This Useful Post:
    ArtemK (14th July, 2020), irfa (14th July, 2020), sonices (14th July, 2020)
  21. #1020
    Jul 2020
    Yes, 0823 is correct.
    Thank you very much!
