Results 1 to 5 of 5
    Serbia
    Default Alternator Voltage Regulator How to Test??
    Hi to all!!
    How to test Voltage regulators from example from Ford Mondeo 1.8 tdci with 3 pin conector?
    dopsleutel13's Avatar
    Dutch
    Voltage Regulator Test | eHow.com
    look here on the greatest manual on the internet !
    Al clear explaned for the car specialist .
    Succes
    Staffs UK
    1) check battery voltage
    2) start engine and re-check
    3) remove 3 pin plug and check again
    clear fault codes with diagnostic tool if output checks out OK
    The "smart" alternator will work as a standard alternator if you remove the 3 pin plug. (genuine one only NOT spurious)
    One of the wires to the three pin plug breaks give them a pull test.
    Meat-Head's Avatar
    Quote Originally Posted by nutloose View Post
    1)
    holds at 13.8 second above
    Meat
    IF YOU WANT TO CHECK THEM OUTSIDE OF THE CAR.......LIKE A SPARE PART.........YOU CANT........!!!!ON THE CAR.....
    1 CHECH BATTERYS VOLTAGE
    2 START THE CAR AND TEST AGAIN....IF THE REGULATOR IS GOOD YOU MUST HAVE 13.8 TO 14.5 (DEPENDING OF THE CAR)
