Results 1 to 12 of 12
    Unhappy Frozen Image on Sagem 1 Dbox
    Newbie my 1st post. Could someone please help me ,
    Image on box is Lincsat7.251x and has frozen on start up after I tried to flash lakys-sylas-2x by mistake.Now cant get original image to budge.
    What have I done?
    Member BoomBoom's Avatar
    Youll need to use IFa and re-flash it, lots of info out there on doing it, just make sure its the correct image chip size either 1x chip or 2x chip
    Thanks for reply but I have tried that and it will not go anywhere after image says loading kernal
    Jun 2008
    Quote Originally Posted by idekuk View Post
    u ain't dun it right then......IFA Image Flashing Assistant TuT.rar
    Instructions to Flash a box
    you will need to get hold of a few items to sucesfully flash your box
    1. A cross over cable (not to be confused with a patch lead)
    2. A Null Modem Lead (can be bought in all the usual places)
    3 Some sort of flashing utility (i use IFA)
    4 Pc or lappy (turned on)
    5 Dbox2 (turned off)
    Connect the leads from the network card in the pc to the box
    make sure the network card is either set to auto detect/negotiate
    or set to 10 mbits half duplex
    turn off any firewalls as this can slow the process
    Connect the null modem lead from Pc to Box
    Run software setting up the modem port (either com1 or com2)
    Choose the correct image (either 1 chip or 2 chip)
    And press the start button on the software
    Once its done its checks it will wait
    This is where you put the power cord in the box
    after a second or 2 the Tv screen will show the flashing screen
    wait till all is finished then close down the flashing program
    pull out power cord on box wait 10 seconds then plug in
    If you follow all this you should be viewing your new image on your box
    now it is a matter of setting location in the settings to your vilage/town
    doing a scan (takes between 5 and 50 mins)
    and way you go
    Yea got all that, so I,ll just keep trying. Be tomorrow tho as got to go to fottie tonight Thanks again
    If you get issues try a diff version of IFA as some work more than others
    have tried everything but box will still not move from image showing Linux ..loading kernal.
    getting a bit worried now. Is my box knacked?
    Top Poster + Derekwd's Avatar
    May 2008
    Did you manage to flash an image to the box, did it finish flashing successfully
    Derek
    Quote Originally Posted by MetMan View Post
    Groundhog day again i guess
    Member spankmonkeywill's Avatar
    Jun 2008
    Plymouth Devon (Scottish)
    mate i have had this before by interrupting the flash process. Make sure you use a program like ccleaner in between attempts and look for the folder created by IFA when you fail to flash successfully. Bin it before another attempt. Its a pain in the a** but its always worth rebooting the comp after continued failed attempts.
    Follow the above instructions provided by boomboom. keep the cables out ov the box and power off BEFORE launching IFA
    got worse today. tried to ftp on my other box dbox2 and it has done the same.
    both boxes are now stuck on loading kernal. This is now doing my box in if you pardon the pun;;; I have been able to flash any image many times before but this has really
    got me puzzled. CAN anyone tell me where I am going wrong. Have been using Flashfxp,
    Dbox ifa,total commander,and tried firezilla Heeeeeelp please
