Results 1 to 8 of 8
    Default Start Das via Xentry
    Does anyone have this problem after they install the 03.2011 Das version ?
    I used to use the shortcut Das32r2.exe - len for the last 2 years even with the 01.2011 Das
    but with the 03.2011 it stoped to work.
    Seems like DAS only opened by Xentry
    thanks but I have seen the following pic
    If one runs from xentry, he will never see this screen
    Run Xentry->DAS->Esc>Initial menu, can you access that page as attachment? Not yet receive my 03 update will try when it arrives.
    When I press ESC, it only asked "End Das"
    So I believe there must a way to run the das without Xentry....
    Thank you.
    Edit:
    I replaced the DAS32R2.exe with the 01.2011 one, then I can run das directly from the shortcut, so I guess the new DAS32R2.exe needs to be patched before we can use it normally like before.....
    That's cool! Thanks for your information!
    It works fine after replaced with the old version....
    Earth
    Please, share previous file.
