Results 1 to 15 of 24
    Default Instructions for OP-Com update
    can someone make a small guide that the OP-COM (clone) can upgrade to v1.44 firmware.
    If possible with pictures.
    Does that make the OP-COM Advance?
    Ashraf6119's Avatar
    UK
    The normal Op-Com and Op-Com Advance are two different things so, there is NO way by updating up your clone Op-Com to become Op-Com Advance.............
    And if you are thinking of updating your Clone op-Com than you can update it from this site here which is tested and its working with clone once................
    http://opcomforum.yolasite.com/software.php
    Hope this helps........
    Ash
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
  3. The Following User Says Thank You to Ashraf6119 For This Useful Post:
    zecozc (9th February, 2019)
    DK Veteran mishu_b's Avatar
    Land of Choice!
    just run the last Op-Com software and your tool will automatically update to fw 1.44.
    atb
    What is the last software for OP-COM Clone?
    Land of Choice!
    according to the rules (new rules) you will not find here the last software for clones.
    atb
    And whats the number?
    Land of Choice!
    OP-COM CHINA 08-2010 - one of the last Op-Com software cracked - usable with clones.
    atb
    Jan 2011
    Update can be easy, if you will use this loader with FW1.43&1.44
  10. #9
    Jun 2011
    Hello! If I install latest version of op com, I will automatically updates the interface to version 1.44? Thanks to all
  11. #10
    RMCtech's Avatar
    Mar 2011
    Yes, if you use latest soft it will update your clone to 1.44 but many functions will not work, and you will have an almost useless interface.
    My advice is: Forget the v1.44 firmware, it don't work fine on clones.
    The latest usable soft in clones is firmware 1.39 of China OP-Com 08-2010
  12. #11
    Land of Choice!
    correct
    you do not need to update the interface because the last working software with clone tool is op-com 08-2010 which required fw.1.39
    atb
  13. #12
    Oct 2008
    On Earth
    Mates yes that's right like Mishu_b said that you don't need to upgrade to 1.44 just because Op-Com china clone 08/2010 need fw 1.39.
    But I cannot tell you that Op-COm not works well with fw 1.44
    There's not any difference between 1.39 and 1.44 if use all cracked version of Op-Com.
    Good luck
  14. #13
    Usa
    i have original. but cant find any serious website that speak about even official updates ive too much problems getting them who czn help?
  15. #14
    meteor80's Avatar
    Confirm.
    Version 1.44 is a piece of sh*t.
    It doesn't work with same modules like Airbag or dash.
    1.39 works fine.
    Work is a primitive way to spend Your free time.
    F.Kiepski.
  16. #15
    Oct 2008
    On Earth
    May you explain or named the controlers that you couldn't connect?
    I mean the models on which cars?
    Becasue that's something new for me what you said. I have an upgraded 1.44 tool and I haven't no problems to connect on any moduls.
    So I'm intrest to check by my self.
    Good luck
