Results 1 to 7 of 7
Thread: TecDoc Problem
    V.I.P. Member steppenwolf's Avatar
    Mar 2009
    Serbia
    Post TecDoc Problem
    I have tecdoc problem on windows 7. I have installed version 2011/1 and when I start and pick some car model everything is gray. Can't access. I have tried with 2010 version and the same thing is happening.
    Any ideas?
    Mar 2009
    Serbia
    Post
    Solved Thanks anyway!
    Feb 2009
    Quote Originally Posted by steppenwolf View Post
    how do you solved this problem ? could you share your idear ? thanks
    Mar 2009
    Serbia
    Post
    Quote Originally Posted by Sev17teen View Post
    Go to tecdoc install directory, find the file tof.exe, properties and then set compitability to Windows XP Service Pack 2. Aplly then run the program from desktop. That`s it.
    Regards!
    tks a lot.
    Jan 2011
    Mazatlan, Mexico.
    Regards!
    Sadly everything automotive is made to NEED the "Compatibility Mode".
    Hope all the manufacturers could just update the software =/, Thank God Windows 7 is good at emulating XP.
    Mar 2009
    Serbia
    Post
    Quote Originally Posted by MarcEcko View Post
    They will update s/w. TD 2011/2 is ok with windows 7 (64-bit).
